It is currently Thu Jul 03, 2025 5:20 am
 Post subject: 6 wheel passenger trucks for lightweight cars
PostPosted: Tue Sep 26, 2023 11:02 pm
I recently became aware that some lightweight cars were outfitted with a GSC lightweight truck in 6-wheel arrangement. A car body that I know of which used them, and probably still needs them, is the Illinois Central "Gulfport" at Monticello. Is even one set of these trucks around in preservation?
 Post subject: Re: 6 wheel passenger trucks for lightweight cars
PostPosted: Wed Sep 27, 2023 12:25 am
I only was able to find one in-service photo of the Gulfport (IC 3312) and it looks like the truck on the tail is 4-wheel. https://www.flickr.com/photos/john_stev ... 5968134837 Edit: I also found the top photo of the Gulfport, but it is hard to see at that angle.
The car below may be a lightweight car (or then again could be a modernized heavyweight car) is painted for IC and has six axle trucks, it was part of a restaurant at the Lincoln IL former GM&O station, but was donated to Iowa Pacific, who then let it be vandalized, and I think it was eventually scrapped. I am not sure of the number:
PostPosted: Wed Sep 27, 2023 1:40 am
The Southern Pacific business car, Sunset, car 150, built in 1955 was built with 6 wheel trucks. I was told this because the car was so heavy, but it also could have been to provide a better ride. I believe the car is still in service on the Union Pacific.
PostPosted: Wed Sep 27, 2023 11:14 am
Don't know what your source is for that information regarding Gulfport, but it was, along with the rest of the new equipment built in 1942 for the new, streamlined Panama Limited, built with two-axle trucks.
File comment: ICRR car diagram for Obs cars Gulfport and Memphis.
ps17.pdf [188.42 KiB]
Downloaded 224 times
However, ICRR did extensive car work at their Burnside Shops in Chicago, taking many, many old heavyweight cars, stripping them to the center sill, and building new carbodies on the remaining frame, resulting in a first-glance appearance of a lightweight streamlined car. The cars were still heavy, so re-utilizing the three axle trucks was necessary, and those too were modified with roller bearings, bolster anchors, and truck mounted brake cylinders/slack adjusters for satisfactory use at ICRR's 100+ mph speeds between Champaign, IL, and Branch Jct., just north of Centralia, IL. Maybe photos of one of those with a round end has someone confused?
PostPosted: Thu Sep 28, 2023 5:22 pm
I suspect that the observation is IC 3320, "Paducah" which was rebuilt from heavyweight coach 2173 for the Louisville - Fulton of the "City of New Orleans". The window pattern matches that of 3320 which was originally a "coach-lounge-observation". It may have had an interior reconfiguration after this service to make it a full lounge. Further, I would guess that the train that it is on is the "City of Miami" with a repainted NP dome sleeper and a stainless steel car in the consist.
As for lightweight cars with six wheel trucks, the GM&O received eleven coaches in 1947 and four parlor cars in late 1947/early 1948 that rode on six wheel trucks.
In 1956, Missouri Pacific received six 10-6 sleepers with six wheel trucks. Greg Stout's "Route of the Eagles - Missouri Pacific in the Streamlined Era" speculates that the cars were equipped with these truck for operation on the branch to Hot Springs, AR, which was laid with relatively light rail.
PostPosted: Thu Sep 28, 2023 8:27 pm
"However, ICRR did extensive car work at their Burnside Shops in Chicago, taking many, many old heavyweight cars, stripping them to the center sill, and building new carbodies on the remaining frame, resulting in a first-glance appearance of a lightweight streamlined car. The cars were still heavy, so re-utilizing the three axle trucks was necessary, and those too were modified with roller bearings, bolster anchors, and truck mounted brake cylinders/slack adjusters for satisfactory use at ICRR's 100+ mph speeds between Champaign, IL, and Branch Jct., just north of Centralia, IL."
Many of the IC heavyweight rebuilds received all-new outside swing hanger three axle trucks, such as is seen under the car in the picture that was part of the restaurant.
Additional non-baggage/storage mail/baggage RPO postwar lightweight cars with three axle outside swing hanger trucks include the New Haven 1948 "American Flyer" diners and grill diners built by Pullman-Standard at their Worcester, MA plant.
PostPosted: Thu Sep 28, 2023 9:32 pm
I almost forgot all of the Union Pacific lightweight baggage cars on six wheel trucks, some of which went to RBB&B for elephant cars. Only one made it to Amtrak, their number 1139, but it perished in the Bayou Canot tragedy on No. 2.
PostPosted: Fri Sep 29, 2023 1:26 am
thanks for correcting my info on the car at the Monticello Railway Museum.
Sorry, my source for the reference to Gulfport must have been a badly characterized postcard on Ebay. The car in question on this image is 3305, probably a converted heavyweight. I think it was later owned by Iowa Pacific.
PostPosted: Fri Sep 29, 2023 7:40 pm
"I almost forgot all of the Union Pacific lightweight baggage cars on six wheel trucks, some of which went to RBB&B for elephant cars. Only one made it to Amtrak, their number 1139, but it perished in the Bayou Canot tragedy on No. 2."
Amtrak actually ended up with one other 85' ex-UP baggage car that was built with 3 axle OSH trucks. I don't have the number off hand, but I believe it was an ex-Alaska RR car via a PV car shop to Amtrak. The PV shop swapped the 3 axle trucks - which had high value at the time - and replaced them with a set of OSH 2 axle trucks from another UP car. This car was one that was sold off during the big Amtrak baggage car/diner/crew dorm sell-off of 2017.
PostPosted: Sat Sep 30, 2023 9:54 am
[quote="o anderson"]thanks for correcting my info on the car at the Monticello Railway Museum.
[img]https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Ftse3.mm.bing.net%2Fth%3Fid%3DOIP.Zt118uduhvAh9eED-C8O_AHaFj%26pid%3DApi&f=1&ipt=98dd38099cad364f5ff37ecc4fb4773bb70e8850b584e414c6141974c8703442&ipo=images[/img][/quote]
I don't believe that the car initially pictured in this thread is 3305. 3305 has five windows in the rear observation and lounge portion. The car pictured has six windows which was the window arrangement in "Paducah". Of course, it is possible that one of the windows could have been sealed over.
PostPosted: Sat Sep 30, 2023 3:22 pm
Only the UP 6300 series (6300-6324) of 85' baggage cars had 6-wheel trucks. At 85' over pulling faces these were some of the largest baggage cars built.
PostPosted: Sat Sep 30, 2023 3:31 pm
6-wheel trucks in the modern era were under the Budd-built full domes on the Great Northern and the Santa Fe. Also the Santa Fe hi-level dining cars for the El Capitan rode on 6-wheel trucks.
Users browsing this forum: Google [Bot] and 98 guests
