It is currently Tue Jul 08, 2025 10:59 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: WM 1309 better video
PostPosted: Wed Dec 01, 2021 3:02 pm
Dave wrote:
The jets were as you might expect very small nozzles blowing steam in through the much larger ports through the water legs which were to force air over the firebed to combust the volatile gases given off by the coal - much as coking gave off gas usable for domestic use (lighting and cooking) in my grandfathers day. The turbulence also was to lead to mixing the air with the volatile gases to increase combustion efficiency. I understand they were loud.... but have never been around them in use. The draft from the front end should pull air in through the openings anyhow without jets.... I think it depends on the amount of coal you need to burn in a given amount of time as to whether the overfire draft needs the assistance of forcing more air in or not as well as the quality of the coal itself. Porta made much use of overfire air in his Gas Producer Firebox designs.
In later years, 734 also had overfire jets. Three on each side. We used them for clearing up the stack when the engine was standing or drifting (never when working significant throttle), at times when excessive smoke was a concern. They were quite loud, but very effective. Before they were installed we sometimes used the stoker jets for the same purpose (turned up way higher than what was necessary to actually use the stoker), which worked but not as well.
PostPosted: Wed Dec 01, 2021 3:08 pm
Do they cause premature wear of the side sheets?
PostPosted: Wed Dec 01, 2021 7:56 pm
SteamEnthusiast4000 wrote:
Where did you get this diagram from, if you don't mind my asking?
No problem at all. It's a scan from my copy of Steam Locomotive Diagrams of the Chesapeake & Ohio Railroad, compiled by the late Alvin F. Staufer in a small paperback back in 1964.
PostPosted: Fri Dec 03, 2021 8:41 am
This video features 1309 stopping just before Helmstetter's Curve for a crewman to flag a crossing, then catches the 2-6-6-2 starting up the grade
https://www.youtube.com/watch?v=CiDFOEm622s
And here's another video, this one showing 1309 moving along at a good clip
https://www.youtube.com/watch?v=jNqlfYnuU6k
PostPosted: Fri Dec 03, 2021 10:09 am
The exhaust sound is much lower than a traditional non compound, interesting to hear that.
Something like the 4014 or 1218 would have that characteristic double exhaust starting the train up again on the grade.
PostPosted: Sat Dec 04, 2021 10:38 am
I’ve watched a few clips of the locomotive but I haven’t yet caught one where you can hear it switch from simple expansion when starting the train to compound expansion for running.
Has anyone caught that on a video?
PostPosted: Sat Dec 04, 2021 3:18 pm
That's because when the loco starts normally, the rear cylinders exhaust to the receiver, not the atmosphere. The exhaust passage from the HP cylinders to the stack is closed off. As a result, the loco sounds "normal" because only the LP cylinders exhaust to the stack, giving four exhaust per driver revolution. Only when the engineer opens the emergency valve (or sometimes called the simpling valve), then the exhaust from the HP cylinders goes to the stack, along with the exhaust from the LP cylinders, and you get the unique sound of eight exhaust beats per driver revolution. Interesting setup on the "old" compounds, which excludes the modified N&W Y's. And this is a highly simplified explanation of how it all works.
For a more complete explanation see http://www.catskillarchive.com/rrextra/mallet.Html
PostPosted: Sat Dec 04, 2021 3:46 pm
Makes you wonder if steam development had continued would more articulated locomotives have been simple or compound. Wasn't the planned NW y7 a simple engine?
N&w seem to have been one of the masters of compounding so interesting that on their next planned Y series they wanted to go simple.
PostPosted: Sat Dec 04, 2021 3:53 pm
I have to concede that I've only "lived" this via audio recordings (N&W Y6's by Link, and overseas compound Mallets), but:
What I have heard is compounds using "simple," meaning direct steam to all four cylinders, to get the heavy train moving, with eight beats per driver rotation unless they somehow magically "sync," and then as the engineer is confident he has the train on the roll, a dramatic cut from eight to four exhausts per rotation as the loco is switched from simple to compound for more efficient use of steam. You don't use compounding to get a train started--you need as much power as you can get from all four cylinders.
It's as if you were listening to a doubleheader, and all of a sudden the one loco disappeared.
Someone knows which Link recording(s) these were; I'm thinking it was the last track on Side B of "2nd Pigeon and the Mockingbird".......
PostPosted: Sat Dec 04, 2021 8:23 pm
I read that they’re still adjusting the simpling valve, so that might have something to do with the sound being off. That or there was just no video taken at a time that would’ve presented the engine simpling. Maybe whenever she gets out onto the line again and there’s more cameras we’ll hear it.
Either way, here’s where I saw that the simpling valve seeds fine tuning:
https://railfan.com/she-looked-glorious ... -maryland/
PostPosted: Sun Dec 05, 2021 3:11 am
I have to concede that I've only "lived" this via audio recordings (N&W Y6's by Link, and overseas compound Mallets). . .
Ah, you're in luck, there are several instances of N&W Y's shifting from simple to compound (though only "2nd Pigeon and the Mockingbird" has the engine shifting from compound to simple), and that at considerable distance).
The whole of any of these recordings--the only complete examples I can find on the internet--are worth listening to, but the specific shifting sequences that may be of interest here are at:
"Sounds of Steam Railroading"--Sequence opening at 7:10 (switching with a Y at Waynesboro, Va.), departure in simple starting at 14:16, transition to compound at 15:45:
https://www.youtube.com/watch?v=UhBFD5JrKUE
No compound Mallets at all on "The Fading Giant," but a wonderful ride behind Js (one of them being 611, reportedly the only sound recording of her in revenue service), a 4-8-2 being moved for servicing at Bristol with a clanky, rattley turntable as a costar, M-class 4-8-0 382 with a beautiful whistle on the Abington branch, and the famous Christmas sequence at Rural Retreat, Va.:
https://www.youtube.com/watch?v=Sl4S4YKi70Y
Hooters call out, sounding like ghosts, accompanied by "Thunder on Blue Ridge." This must be an earlier edition of this record (it has some differences compared to the later one I was able to mail order from Link when he was still alive). It's hard to make out, but the first transition from simple to compound is in a sequence that starts at 4:45 (Link was standing somewhere near the center of the train as it got under way at Boaz, Va., the base of the grade); actual transition, barely audible (at least to me) is at 5:55 (it was interpreted as a slip by the fellow who wrote the liner notes).
At 9:00, we're about to go up the hill in the caboose as the pusher couples on. You can hear the intercepting or simpling valve flipping over a couple of times, eventually the train gets under way in simple . . .at 13:32 is a sequence where it sounds like the pusher drops into simple at 13:38. . .between 32:57 and 33:08 the engine goes back into compound (at least that's how I'm interpreting it). . .at 33:27 the rear brakeman pulls the pin and the pusher drops behind. . .there's still a bit more of the adventure, but it's not involving changes in steam flow, and I won't spoil it for you anyway!
https://www.youtube.com/watch?v=-LEjixDk5lg
There may be other sequences featuring this action on other records, among them those sold by the Railroad Record Club, but I haven't heard them and can't comment on them. Some of those are also on YouTube.
Users browsing this forum: CentreKeystone and 190 guests
