It is currently Fri Oct 16, 2026 1:01 pm
 Post subject: Jacobs Schupert firebox
PostPosted: Tue Feb 12, 2013 3:14 pm
Jacobs Schupert "sectional" firebox.
What do you guys know about these.
Jacobs-Shupert United States Firebox Company
here is a link to the test of a staybolt firebox and one of the Jacob Shupert versions; http://books.google.com/books?id=d39MAA ... ox&f=false
 Post subject: Re: Jacobs Schupert firebox
PostPosted: Tue Feb 12, 2013 3:31 pm
It was a firebox design that did away with staybolts, but was prone to corrosion at the seams (at least on coal fired boilers) and leaks. The Santa Fe experimented with them as part of their Mallet locomotive experiments.
http://www.steamlocomotive.com/2-6-6-2/?page=atsf
Others experimented with them as well; but it was never widely adopted.
-James Hefner
Hebrews 10:20a
PostPosted: Tue Feb 12, 2013 3:38 pm
With plasma, laser and all the other sheet metal cutting processes and the incredible welders we have available today, maybe its economics, and its time have arrived.
If it offers a larger margin of safety, that reduces insurance rates.
It might also reduce boiler mntc. costs significantly.
PostPosted: Tue Feb 12, 2013 3:52 pm
My memory tells me that another problem with this firebox design was that it was not easy to repair; I believe you had to take it completely apart and rebuild it instead of just replacing stays or patching like a conventional firebox.
-James Hefner
Hebrews 10:20a
PostPosted: Wed Feb 13, 2013 12:55 am
The owners of these must have been betting on no internal mntc. for long periods of time to make these economical.
It might be difficult to inspect, unless you used a scope. Then when you found damage you would have to cut the thing apart to get to it.
What if in service you could get 20 years out of a J-S firebox and have no internal issues, I suppose the question is then: What are the annual costs of stay bolt replacements in a traditional firebox, and is that cheaper than no stay bolt issues, and a J-S firebox replacement for a 20 year period.
