It is currently Mon Nov 02, 2026 10:22 pm
 Post subject: CN 2534
PostPosted: Fri Sep 08, 2006 11:38 am
Displayed with cars at Brighton, Ontario:
http://abpr.railfan.net/abprphoto.cgi?f ... 656-FC.jpg
http://abpr.railfan.net/abprphoto.cgi?f ... 663-FC.jpg
 Post subject: Re: CN 2534
PostPosted: Fri Sep 08, 2006 5:09 pm
Bob:
Neat looking engine but that bell..............??!
PostPosted: Fri Sep 08, 2006 6:06 pm
Looks like an inverted flower pot.
Wesley
PostPosted: Fri Sep 08, 2006 11:54 pm
Guys, I think you are right about that bell being an inverted flower pot. By the way, did anyone notice that the valve gear seems to be missing?
Gary
PostPosted: Sat Sep 09, 2006 11:59 pm
It's not missing. It has Stephenson valve gear instead of the more common Walschaert valve gear. Stephenson valve gear is mounted between the wheels.
PostPosted: Sun Sep 10, 2006 9:03 am
While the engine has stephenson valve gear I think Mr. Gray is refering to the missing valve rod and apparently the the linkage connecting it to the links. This can be seen in the view of the left front of the engine. The bell cradle is an odd arrangement.
John Bohon
PostPosted: Sun Sep 10, 2006 10:43 pm
Thank you John. As a proud member of the Civil War Railroads Historical Society, as well as a modeler of 1860's railroading, I am well versed in the eccentricities (pun intended) of the Stephenson valve gear. Anyone up for a philosophical discussion of the Baldwin-Cuyahoga variable cutoff gear?.......... :)
Gary
PostPosted: Tue Sep 12, 2006 1:44 pm
The bell is made of some sort of wood or plastic I believe. The number plate below the headlight is carved from wood by a friend of Mr. Bangay who owns the museum. They did a nice job. If you check out the website they show how the engine was delivered in pieces and some people said they'd never get it back together again! Looks to me like they did an amazing job.
