It is currently Mon Nov 02, 2026 1:35 pm
 Post subject: Very early color photos
PostPosted: Sun Jun 04, 2006 12:14 pm
On the ABPR for 11/26/04, there are some very early color photographs posted by Bill Blomgren (usually noted for his thousands of EBT photos on the same site), said to have been taken at the turn of the 20th century in Russia. The photographer was apparently assigned to the Tzar and had a train at his disposal. The process apparently utilized a sandwich of three glass plates, but I do not know if hand coloring was involved or not. One example below:
http://abpr.railfan.net/abprphoto.cgi?n ... rkshop.jpg
 Post subject: Re: Very early color photos
PostPosted: Sun Jun 04, 2006 1:22 pm
I have seen the book. It is interesting and worth a look, some pix
look quite real. I m not sure, but I don't think they are hand colored.
Photographs for the Tsar: The Pioneering Color Photography of Sergei Mikhailovich Prokudin-Gorskii Commissioned by Tsar Nicholas II
Robert H. Allshouse (Editor), Sergei M. Prokudin-Gorskii (Illustrator)
You can find it used.
PostPosted: Sun Jun 04, 2006 3:44 pm
The technique is in essence a "still version" of the Technicolor process. Three b&w negatives are shot one at a time, through three different filters. They are then developed, and "pin-registered" so that they will print correctly. Finally, each negative is exposed in turn onto a sheet of dye-transfer color paper using the appropriate color light, and the paper developed.
That's why you see the cyan, magenta and yellow bands at the edges.
JAC
PostPosted: Mon Jun 05, 2006 12:31 am
I have a copy of the book. Very interesting.
The following is from the introduction:
He had, in fact, developed a system of producing three-part color photographs that could be projected simultaneously. Using a small folding hand camera of the type designed by Mieth, he photographed three exposures of the same subject, made at about one-second intervals on a glass plate approximately 84-88 mm wide and 232 mm long, which was mounted vertically in the camera. The plate dropped to a new position after each exposure, and the image was captured through three different color-separation filters. Because of the need to take the same picture three times, Prokudin-Gorskii was limited to subjects hat would make no movement. Thus, much of what he recorded consisted of fixed objects.
He had also developed a special treatment that hypersensitized the Ilford “red label” plates he was using. After developing, the images could easily supply contact prints, from which excellent color photographs could be made. The remaining problem lay with overcoming the difficulties that arose when the standard projection systems were used in conjunction with his three-part separations.
His unique solution was a projector first developed by F. E. Ives, which he modified so that “from the point of view of rapidity of arrangements and quality it gave better results…” He had it constructed in Germany to his specifications, using three rhomboidal prisms cemented together to make one combination prism. By adjusting the focal lengths and correcting for distortion so that the optical distances became equal, he was able to focus the three colors on the screen precisely.
PostPosted: Mon Jun 05, 2006 8:54 pm
The device that projected these images looked like a traffic signal, with three lights (red, yellow, green) on top of each other. Plates were put behind each light and the images were projected onto the same screen, giving a color result.
There is a web site with many of these pictures, which are generally very interesting.
Chris.
PostPosted: Tue Jun 06, 2006 10:38 am
And the website is?
