It is currently Mon Nov 02, 2026 9:54 am
 Post subject: Steam air pump air oil - who's using what?
PostPosted: Fri May 19, 2006 7:41 am
What are you guys using in the air side of your air pumps that is economical and easy to obtain?
Good judgement comes from experience, experience comes from bad judgement.
 Post subject: Re: Steam air pump air oil - who's using what?
PostPosted: Fri May 19, 2006 11:32 am
Dear Ray:
Valley Railroad uses Shell Morlina 220 (and has for many years).
That being said, folks have used all sorts of oils successfully, in compressors that are well maintained (read don't run hot) with good rings, proper check valve lift, check valves that don't leak.
Hot compressors mean hot oil that gets gummy and carbons up the compressor, and coats the internals of the air brake valves with a varnish like substance.
Good luck.
J.David
P.S. We once bought a synthetic oil that worked great but smelled awful as it was exhausted out the H-6 valve when the brakes were released. We ended up piping the exhaust out the floor of the cab (but you could still smell it). JDC
PostPosted: Fri May 19, 2006 5:36 pm
Estrolene. It really keeps the lines clean, however, if your lines are dirty to begin with, the Estrolene will loosen all that gunk rather quickly!!
PostPosted: Sun May 21, 2006 2:28 pm
Where do you purchase Estrolene from and what weight do you use (if there is a choice)?
PostPosted: Sun May 21, 2006 4:29 pm
We obtain the Estrolene 30 from RSI HVAC in Fairfield, NJ you can reach them at 973-227-7800
PostPosted: Tue May 23, 2006 7:05 am
Thank you guys for the replies and information.
Ray
PostPosted: Tue May 23, 2006 9:24 am
We always had excellent luck with Interlube Carbonless Air Oil.
We also used Interlube Steam Cylinder Oil with super results.
 Post subject: Interlube air oil.
PostPosted: Tue May 23, 2006 9:46 am
Is there a product number or product code number for the interlube air oil?
Have you experienced gasket failures from using the interlube air oil? We have used Anderal which is a good oil but attacks certain synthetic gasket materials. I have heard that Estrolene will do the same.
 Post subject: Re: Interlube air oil.
PostPosted: Tue May 23, 2006 8:22 pm
If memory serves, it's calle #5 Carbonless Air Oil.
I think after a few years, we did have a gasket kind of swell up, but it took a long time. We had put it in a jar full of the air oil and closed it up and monitored it every so often.
Don't know about the Anderoil.
