It is currently Sat Oct 17, 2026 2:27 pm
 Post subject: Locomotive Tires
PostPosted: Mon Sep 10, 2001 4:13 pm
Is anyone aware of the reason that the FRA does not allow for welding(building up) of steel locomotive tires?? Thanks in advance for the information.
 Post subject: Re: Locomotive Tires
PostPosted: Mon Sep 10, 2001 4:18 pm
All I have ever been told was the stress and imperfect welding that could occur. However, many flanges were welded and turned during WW2, and there is a ATSF Consolidation that had its tires welded to the centers as late as the early fifties, in ICC service.
lorija799@aol.com
PostPosted: Mon Sep 10, 2001 8:26 pm
The tires are high carbon steel. To properly weld they would have to be removed from the wheel, preheated, welded, annealed, and x-rayed. The result MIGHT be safe.
It would be much easier simply to apply new tires, and probably not much more expensive. Can someone post a vendor for tire blanks?
johncb@u.washington.edu
PostPosted: Mon Sep 10, 2001 8:33 pm
TVRM uses Standard Steel for tires. The name of the contact person there escapes me at the moment.
Tennessee Valley Railroad Museum
aw90h@cs.com
PostPosted: Tue Sep 18, 2001 11:29 pm
Edgewater used to make tires too.
You can't weld on axles or regular wheels either.
PostPosted: Wed Sep 19, 2001 10:50 am
> the moment.
If my file is still correct from about a year ago...
Standard Steel
500 North Walnut Street
Burnham PA 17009
Ned Kauffman
Rwy Market Mgr
717-242-4621 Direct
717-248-8050 Fax
Hope this helps
pfdx@aol.com
