It is currently Sat Oct 17, 2026 1:55 pm
 Post subject: new boiler ?
PostPosted: Fri Aug 17, 2001 6:59 pm
Apart from the Texas State 300, anybody out there running a new welded boiler on a FRA regulated railroad?
Dave
irondave@bellsouth.net
 Post subject: Re: new boiler ?
PostPosted: Fri Aug 17, 2001 9:32 pm
> regulated railroad?
> Dave
Dear Dave:
All three of the Chinese locomotive have all welded boilers and all operate under FRA jurisdiction.
I believe that the former V&T 4-4-0 "Reno" has an all welded boiler. It no longer is operable, but might have run under Federal rules while leased to the UP in 1969.
I am told that the "Eureka" was reboilered at some time. Was this a welded replacement? "Eureka" is operated with some regularity on the D&SNGRR.
The new boiler built for the Heisler at Cass is all welded, I don't know if it has been placed in service yet.
J.David
jdconrad@snet.net
 Post subject: Re: Eureka's boiler
PostPosted: Fri Aug 17, 2001 10:31 pm
The last I knew, the EUREKA still has the boiler it had in the later 1930s when Warner Bros bought it. Dan Marcroft has spoken of it being the original steel boiler. Dan told a story of co-opting a neighbor into helping him rivet on a doubler plate on the boiler-kept the neighbor from complaining about the noise.
Due to fire damage when it was at "Old Vegas," Dan replaced the cab, tender frame, etc.
I recall, that the headlight is a reproduction. But all of the brass work survived; Dan did replace the brass on the cylinders because it was just too dented.
bnorden@gateway.net
 Post subject: Opps! Dan's name is spelled Markoff *NM*
PostPosted: Fri Aug 17, 2001 10:38 pm
bnorden@gateway.net
 Post subject: About the Reno..
PostPosted: Sat Aug 18, 2001 2:59 pm
I've asked this before, but never gotten a complete answer. V&T No. 11, the Reno at Old Tucson in AZ was scheduled to be converted to compressed air operation sometime in the 1980s, with a diesel compressor installed in the firebox and large air tanks added in the tender shell. Some have told me this work was begun, others have said it never was. Who knows, and if so, how much damage was done before the project was halted?
Dear Dave:
> jurisdiction.
> in 1969.
> J.David
bobyar2001@yahoo.com
 Post subject: Re: About the Reno.. *NM*
PostPosted: Sun Aug 19, 2001 3:11 am
hgorin@ix.netcom.com
