It is currently Sat Oct 17, 2026 11:23 am
 Post subject: Headlight Bulbs
PostPosted: Thu Jul 26, 2001 10:02 pm
Does anyone have a present supply for 32 volt 300 watt horizontal orientation headlight bulbs?
SZuidervee@aol.com
 Post subject: Re: Headlight Bulbs
PostPosted: Fri Jul 27, 2001 9:46 am
Have you tried Aamsco? They carry a good amount of specialty bulbs. www.aamsco.com
Roger
> headlight bulbs?
Belpaire@aol.com
PostPosted: Fri Jul 27, 2001 11:09 pm
> Roger
The volt is 30 volt Screw terminal base (PAR56-200 watts-30 volt)
Stan
owenpaulsen@att.net
PostPosted: Sat Jul 28, 2001 9:25 am
> Stan
I am not looking for PAR bulbs. I know where to get them. I am looking for P-25 style, medium mogul base, round bulb with no neck.
SZuidervee@aol.com
PostPosted: Sat Jul 28, 2001 9:38 pm
Steve,
just curious what you're needing this for.
The 32 volt p-25 sounds like a Gyralite.
If so maybe the folks at Trans-Lite can aim
you in the right direction.
Stephen
Trans-Lite website
shootpix@hotmail.com
PostPosted: Sun Jul 29, 2001 5:28 am
There is a Philips (was Westinghouse) 200 watt PS-30 32 volt medium screw base lamp in their 2000 catalogue. It's not recommended because it has a C-6 filament, which won't stand up well to vibration. It also has an aluminum base, which isn't any good in my opinion. Also check Osram (Sylvania) and GE.
If you have them custom made, specify a C-5 filament and a brass base. Also be sure to have the manufacturer mount it in the bottom 1/3 of the glass envelope (sorry, don't have a catalogue which gives the dimensions), otherwise you might not be able to adjust the filament into the focus of the reflector.
Screw type lamp bases are, from smallest to largest: minature candelabra, candelabra, intermediate, medium, medium skirted, mogul, mogul 3 contact. There is no such thing as "medium mogul". The thread contour is called an Edison knuckle thread.
PostPosted: Sun Jul 29, 2001 10:02 am
Pete,
I misspoke the base size; it is "Medium". The bulb style is correct, from a ten-fifteen year old Philips catalog the 32 volt locomotive headlight bulb is designated "P-25".
Steve Zuiderveen
SZuidervee@aol.com
PostPosted: Sun Jul 29, 2001 10:40 am
I've checked both Phillips and Sylvania catalogs and neither makes a 300W 32V P-25. The PS-25 mentioned earlier has a long neck which most certainly will not work for what you want. I know from trying to find lamps for passenger cars that 32V is getting harder to find.
I know their website doesn't give much info, but did you try Aamsco?
Roger
> Pete,
> Steve Zuiderveen
Belpaire@aol.com
PostPosted: Mon Jul 30, 2001 4:19 pm
Liz at Aamsco (800-669-9134) has 12 G-25 250 watt, 34 volts loco headlight bulbs on their way to me for $12.91 ea. Wish me luck with UPS!
I will report to the list how they work out.
Thanks to Roger Hahn.
Steve Zuiderveen
> headlight bulbs?
SZuidervee@aol.com
PostPosted: Mon Jul 30, 2001 6:09 pm
Spoke to a friend at Osram who said to try the
Specialty Bulb Co. in Bohemia, NY.
They have two in stock, and say they can get more.
(250w 32volt P-25 Med.base.)
1-800-331-BULB (Lee Besser)
Good Luck,
Stephen
Specialty Bulb Inc.
sjhussar@aol.com
PostPosted: Wed Aug 01, 2001 2:53 am
Sorry about the PS bulb. I forgot the bulb designations: S for [tapered] straight side, A for arbitrary (A-19 is the commonest household lightbulb shape), PS for pear shaped, G for globe, T for tubular, attached numbers refer to the actual size of the lightbulb. Headlights are usually the G type. When I can find the old catalogue, I'll post the appropriate dimensions for headlamp filament to base relationships. These are all Mazda standard specifications, and any lamp manufactuer should be able to make them, proviced they have the mold for the bulb.
PostPosted: Wed Aug 01, 2001 2:54 am
Sorry about the PS bulb. I forgot the bulb designations: S for [tapered] straight side, A for arbitrary (A-19 is the commonest household lightbulb shape), PS for pear shaped, G for globe, T for tubular, attached numbers refer to the actual size of the lightbulb. Headlights are usually the G type. When I can find the old catalogue, I'll post the appropriate dimensions for headlamp filament to base relationships. These are all Mazda standard specifications, and any lamp manufactuer should be able to make them, provided they have the mold for the bulb.
