It is currently Sat Oct 17, 2026 10:43 am
 Post subject: Friction Bearings
PostPosted: Wed Jun 13, 2001 12:47 pm
Hi,
I was wondering what brand of oil you all use to lubricate friction bearings.
Thanks,
Stuart
Frisco 1506
gnufe@apex.net
 Post subject: Re: Friction Bearings
PostPosted: Wed Jun 13, 2001 3:21 pm
A popular product is Texaco Journaltex HD 57, poduct code #674. Go to "product catalog" on the link below.
Texaco Products
PostPosted: Wed Jun 13, 2001 11:28 pm
Our List of Standardized Lubricants for Railway Equipment lists the following:
"Journal Oil or Car Oil:
"For lubricating plain type journal bearings, armature bearings and traction motor suspension bearings made of brass, bronze or with babbitted surfaces. Also used with spring loaded lubricator pads on diesel-electric locomotive traction motors. Can be used with cotton waste, wool waste and fabricated journal lubricator pads. Also used in waste lubricated motor bearing of air compressors, blower motors and dynamotors. Also used with oil lubricated center bearings. Can be used as a general light lubricant oil.
"Most conform to AAR Specification M-963-84
CHEVRON CPS No. 233803 Journal Bearing Oil
TEXCAO product Code 674 JORNALTEX HD-57
UNOCAL product Code 04907 AAR-963 Oil
VALVOLINE M-963-84 All Year Car Oil
"(NOTE: UNOCAL product only made in large lots by special order.)"
We have documented and standardized a list of 35 lubricants for all kinds of uses.
Orange Empire Railway Museum
bnorden@gateway.net
PostPosted: Thu Jun 14, 2001 5:09 pm
> M-963-84
At the Canada Museum of Science & Technology we use an ESSO product on our equipment. Esso is Imperial Oil.
ESSO Galcar. All season journal oil
paul.bown@sympatico.ca
PostPosted: Thu Jun 14, 2001 5:53 pm
I can recommend Interlube "Journal Guard AYG". It is designed to maintain a protective coating on journals that remain static for long periods. We have never had any trouble with rusty, or hot journals, since we have been using it.
