It is currently Fri Oct 30, 2026 6:32 pm
 Post subject: A couple valve gear questions...
PostPosted: Mon Apr 04, 2005 6:22 pm
Hey all,
While doing a bit of research I came upon some papers mentioning some European steam locomotives using Gooch valve gear, which is a type I've never heard of. Would anyone be able to explain it's workings to me, or point me in the direction of a source that would?
And while we're at it, could anyone enlighten me on the subject of poppet valves, (i.e. how they work and the advantages/disadvantages of them)? I know the mighty Pennsy, among others, experimented with these.
Thanks as always!
 Post subject: Re: A couple valve gear questions...
PostPosted: Mon Apr 04, 2005 8:49 pm
The following site has the best "working" explanations of all the various valve types. The working diagrams can be down loaded in a self extracting zip file and gives you quite a bit of information through the various steam diagrams how the valve works. The two of the poppet valves are also diagramed.
http://www.tcsn.net/charlied/
Ed
When you ride a stallion, you never ride alone.
