It is currently Thu Oct 29, 2026 12:09 pm
 Post subject: Builders Records on Ebay Source?
PostPosted: Wed Sep 29, 2004 12:33 pm
 Post subject: Builder's Construction Records
PostPosted: Fri Oct 01, 2004 6:06 am
I have seen the same listings on ebay and they look quite well done. It looks like someone has "cleaned up" the older records that I have been using for 40 years. The main source for these records has been the R&LHS. You can order these records from the R&LHS. I have also built up a library of books that have locomotive rosters. I can then check two sources in case of errors. I can and often help out others with builder's data so do not be afraid to ask.[/b]
