It is currently Sat Oct 31, 2026 8:05 pm
 Post subject: David, It works but.....
PostPosted: Wed Oct 12, 2005 7:22 pm
Site Admin
David:
This is really cool, we've got the entire Webbbs archive, and the Matt's stuff too, in phpbb format.
And it all seems to work pretty good. The threads aren't tied together, but if you do a subject search they all seem to string together pretty well.
The only thing I've found wrong is the name search doesn't work. It works for the new post made thru the normal entry process, all three of them, but not for the thousands of posts inserted from the conversion.
So, that raises a couple of issues, can we fix name search, and is there the possibility that the old names from the conversion, will clash with the new names when the databases are merged.
So, going to try inserting the SQL dump Interland gave us next, and then see if the database merge works.
Talk to you later.
Hume
