It is currently Thu Oct 29, 2026 3:42 am
 Post subject: Ohio injector capacities?
PostPosted: Fri Jul 30, 2004 1:13 pm
Does anyone have a catalog that states the rated capacities in gallons per hour for Ohio lifting injectors? I'm specificallt after the capacity of the #7 size.
SRC Mechanical Dept.
kelly@strasburgrailroad.com
 Post subject: Re: Ohio injector capacities?
PostPosted: Fri Jul 30, 2004 6:34 pm
About the same as they would deliver in Pennsylvania, Kelly.
Not knowing the style but knowing Ohio cloned other types I do have some literature for, I would venture about 2000 GPH wouldn't be far off at 180 PSI.
Maybe somebody out there has an Ohio Brass spec sheet?
irondave@bellsouth.net
PostPosted: Fri Jul 30, 2004 9:12 pm
The ALCO standard practice book(page 55)refers to the capacity of a #7 Ohio injector as 1800 gpm at 200 psi. For each reduction of 10 psi in boiler pressure, reduce the capacity by 2%. This is real close to what Dave said.
johns332@bellsouth.net
PostPosted: Sat Jul 31, 2004 6:03 am
Correction - 1800 gph not gpm!
PostPosted: Sat Jul 31, 2004 6:41 am
Scared me for a minute there!
 Post subject: Thanks for the tip. NM
PostPosted: Sun Aug 01, 2004 1:16 pm
