It is currently Wed Oct 28, 2026 10:59 am
 Post subject: Links Db dead?
PostPosted: Tue Jun 15, 2004 8:02 pm
When I select 'Links' from the menu on the left and then press any button I get the message 'No files were found that meet the current search criteria.' Is it just me of a wider problem?
Puffing Billy Railway, Australia
chairman@pbr.org.au
 Post subject: Re: Links Db dead?
PostPosted: Tue Jun 15, 2004 8:24 pm
I just checked the RyPN Links, and everything seems to be working fine.
Boyd Owens
RyPN Links Administrator
bowens@rypn.org
PostPosted: Tue Jun 15, 2004 8:32 pm
> wider problem?
The links DB was one of my earlier scripting efforts and requires that you accept cookies for it to work correctly. Check and see if you are blocking cookies from the RyPN site. I'm 90% certain that's the problem. If it isn't let me know.
Railway Preservation News
hkading@rypn.org
 Post subject: That was the problem!
PostPosted: Tue Jun 15, 2004 10:45 pm
Check and see if
> isn't let me know.
That was the problem - thanks for the prompt response
chairman@pbr.org.au
