It is currently Wed Oct 28, 2026 3:44 am
 Post subject: Looking for Builder's Serial Info
PostPosted: Sat May 01, 2004 8:42 pm
Is there a website that would have builder serial numbers for locomotives? Interested in any company (but mainly BLW, LIMA, ALCO, EMD), any time.
Thanks!
Joshua
 Post subject: Re: Looking for Builder's Serial Info
PostPosted: Sat May 01, 2004 9:26 pm
The R&LHS has copies of all builders lists of major and minor builders available for a fee. I believe contact info may be found at their web site, but the lists are not, to my knowledge, posted on the web.
> EMD), any time.
> Thanks!
> Joshua
 Post subject: Thank you! N/M *NM*
PostPosted: Sat May 01, 2004 9:45 pm
No Message
PostPosted: Sun May 02, 2004 7:52 am
> EMD), any time.
> Thanks!
> Joshua
Try "Andre's GM Locomotive Serial Number Page" for EMD locos.
A.W. Maples
AMaples@aol.com
PostPosted: Sun May 02, 2004 2:26 pm
I believe this is a myth. I've tried contacting this organization and never got a response. Does anyone have a contact with the organization that they actually KNOW works?
I have some ALCO and Baldwin data, what are you specifically looking for?
Mike
mike211@yknet.ca
PostPosted: Sun May 02, 2004 2:35 pm
> works?
It is not a myth. You need to be an R&LHS member and contact them at this address:
"Locomotive Rosters & Records of Builder's Construction Numbers
The Society has locomotive rosters for many roads and records of steam locomotive construction numbers for most builders. Copies are available to members at twenty-five cents per page ($5.00 minimum) from R&LHS Archives Services, PO Box 600544, Jacksonville, Florida 32260-0544. A list of available rosters is available for $2.00. "
http://www.rrhistorical-2.com/rlhs/
eledbetter@rypn.org
PostPosted: Mon May 03, 2004 1:55 am
Please contact me off line as I have a large library built up over many years. I can probably help you out with most numbers. I have the R&LHS records and other back up rosters to double check some construction numbers.
steamfan@crusoe.net
PostPosted: Mon May 03, 2004 9:08 am
> EMD), any time.
> Thanks!
> Joshua
Josh,
Here's an EMD websites to check out
John
Unofficial EMD homepage
PostPosted: Mon May 03, 2004 9:11 am
> EMD), any time.
> Thanks!
> Joshua
...and one more.
Tom Lundeen's EMD page
