It is currently Wed Oct 28, 2026 12:50 am
 Post subject: pardon my ignorance, but...
PostPosted: Thu Apr 22, 2004 9:47 pm
what exactly did a 1885 Crosby Steam Engine Register register? milage? engine-hours?
utweyesguy@aol.com
 Post subject: Re: pardon my ignorance, but...
PostPosted: Thu Apr 22, 2004 10:11 pm
probably revolutions of a shaft on a reciprocating stationary engine
PostPosted: Thu Apr 22, 2004 11:03 pm
It registers the number of revolutions on an engine crankshaft, not like a tachometer, but the total revolutions from a set point such as the installation or a rebuild. they were used in powerhouses on statioary engines for maintainence purposes. We had a simular counter or register on some old compressors in a older powerhouse in worked in.
captbuck@comcast.net
PostPosted: Fri Apr 23, 2004 9:26 am
> in.
I have seen these gau ges on old water pumping engines. They were used to count the revs. per hour and thus you could tell how much water was pumped.The big old pumping eng. worked at abou t 5 to25 revs. per min. bb
