It is currently Tue Oct 27, 2026 3:49 am
 Post subject: Imitation Gold...What Color is This?
PostPosted: Thu Jan 29, 2004 6:48 pm
OK, with all the recent (and past) discussion about what makes Pullman Green, the question comes to mind: what does imitation gold look like?
Southern Railway moved away from gold lettering on its cars in the mid 1930's, replacing it with a color called imitation gold. Since we are in the process of repainting our SR baggage express car No. 518 (blt 1939), this is a very timely question, and one which I hope has a much easier resolution (although I fear not :^( )
Any takers?
Stephen Syfrett
Thronateeska Heritage Center
Albany, GA
ssyfrett@bellsouth.net
 Post subject: Re: Imitation Gold...What Color is This?
PostPosted: Thu Jan 29, 2004 7:02 pm
One-Shot lettering paint has an imitation gold which is fairly close to what several railroads used when they got away from leaf.
It is available at most auto-type paint stores.
> Any takers?
> Stephen Syfrett
> Albany, GA
wsflco@trainorders.com
PostPosted: Thu Jan 29, 2004 8:54 pm
Our local sign painting supply shop in San Diego has this color on the shelf.
Pacific Southwest Ry Museum
Jim@sdrm.org
PostPosted: Thu Jan 29, 2004 9:07 pm
> stores.
One-Shot and others are colors called "bulletin colors". These are standard colors that are used in the sign-painting industry, and are supposed to be identical from brand to brand, across the country. Of course, with all the fancy computer graphics going giant size these days, I'm sure this will become a "lost art", too.
I also suspect that there is a self-adhesive lettering film that is also available to match bulletin colors, and this has been used to make lettering via computer. Check with a good sign shop.
schwartzsj@juno.com
PostPosted: Thu Jan 29, 2004 9:15 pm
> art", too.
I have used both the One-Shot lettering enamels and the vinyl "decal" material, and the "imitation gold" of each is a close match. Anoteh name for this color (PRR name) is "Lettering Buff" (yes, I know what the obvious punny jokes are....). It is NOT "Dulux Gold", which is a Walthers model railroad name.
Another source for the One-Shot paints are large art supply stores. Pearl Paint on Canal St. in Manhattan carries the stuff.
hpincus@mindspring.com
PostPosted: Thu Jan 29, 2004 9:20 pm
> railroad name.
A sign painter tells me that the present One-Shot IG is not as good to use since lead was banned. . . . Does not cover as well or flow.
It is not a perfect match, but Caterpillar Yellow is pretty close.
SZuiderveen@aol.com
PostPosted: Thu Jan 29, 2004 11:10 pm
So imitation gold is a fairly bright shade of yellow as opposed to a more toned-down shade closer to non-metallic gold?
> Stephen Syfrett
> Albany, GA
PostPosted: Thu Jan 29, 2004 11:31 pm
CGW Imitation Gold Duco 254-54388
Wabash Imitation Gold Duco 254-54292
B&M Gold Duco 254-54015
GN Imitation Gold Dulux 83-50931
L&N Gold Duco 254-35623
fltenwheeler@verizon.net
PostPosted: Fri Jan 30, 2004 7:06 am
One Shot is available in Dick Blick Stores in several locations and on line from Dick Blick. Yes, that is their name, and I believe they are headquartered in Illinois. They have lots of goodies catalogued that are often useful in previously unsuspected ways.
Bob Kutella
68trolley@comcast.net
PostPosted: Fri Jan 30, 2004 7:13 am
No, not a bright yellow at all. The One Shot paint which we have used for many years is almost a pure yellow ochre pigment I suspect. Its perception can take on various hues depending on the background color of the car or equipment. Maybe tan, buff, cream, yellowy clay, but not bright yellow.
Confused? For instance many think the lines separating the orange and green on the classic GN scheme were imitation gold, but in that case they were painted Bright Yellow.
Bob Kutella
 Post subject: Re: One Shot - Read the label
PostPosted: Fri Jan 30, 2004 7:18 am
> was banned. . . .
Actually, I believe that sign painters enamels are not included in the ban on using lead pigments. Some One Shot I bought a few months ago still has the warning that it contains lead based pigments. In my use it flows well, but if you have an old can or one which has been open a long time, one old sign painters trick is to use kerosene to thin it out. This really makes it flow better, and perhaps slower to dry.
Bob Kutella
 Post subject: What Color? It's tan.
PostPosted: Fri Jan 30, 2004 9:55 am
If you saw "imitation gold" by itself you would probably call it a tan or buff. When placed against a Pullman-green or black background, the eye interprets it as yellow or gold. My guess is that the color was chosen to look like gold leaf in sunlight. Which it does, much more so than metallic-gold paints that amateurs often use when they misinterpret the "imitation gold" specification.
This is just one of the many bits of artistry and craft that are hidden in old paint jobs, and which go completely unnoticed until you analyze and try to duplicate these lettering styles.
Aarne Frobom
P. O. Box 665
Owosso, MI 48867-0665
 Post subject: Re: What Color? It's tan.
PostPosted: Fri Jan 30, 2004 10:05 am
> Aarne Frobom
> P. O. Box 665
That's why I'm a "lettering buff"!!!
PostPosted: Fri Jan 30, 2004 5:46 pm
> Any takers?
> Stephen Syfrett
> Albany, GA
Recommened by a friend in the graphic arts department at UC Berkeley:
5522U Imron
5238D Dulux
These should readily cross refrence, particularly the Imron number.
PostPosted: Fri Jan 30, 2004 6:07 pm
In my experiance, Dulux (or Delux) gold and Imitation gold are two different approches to the same problem, replacing gold leaf with paint.
Leaf (gold, aluminum, or whatever) is very thin layers of foil, applied to using varnish or other glue, while imitation gold is a metalic paint, and dulux gold is a yellow paint.
I suspect that there may be local variations in color and name use.
Randy Hees
http://www.spcrr.org
hees@ix.netcom.com
