It is currently Mon Oct 26, 2026 7:49 pm
 Post subject: Journal pads
PostPosted: Tue Jan 13, 2004 11:31 am
Does any one of the name of a supplier of journal pads? I need 16 #8's and our supply is down to 3!! Any help would be most appriciated.
bachtell4@lisco.com
 Post subject: Re: Journal pads
PostPosted: Tue Jan 13, 2004 12:33 pm
> appriciated.
Try Unity Railway Supply Co., 630-595-4562
shaymech@hotmail.com
PostPosted: Thu Jan 15, 2004 2:19 pm
I'm trying to track down the Hennessy Mfg. Co. of Chambersburg, Pa. and pass the information along to this group. The founder made his fortune using the "latteral motion" (slight side to side play) of steam locomotive drivers to power mechanical lubricators. The decendents diversified into "Slidewell" boxcar door openers (a large hand wheel driving a gear down a rack) and journal box lubricator pads, optionally pre-lubricated!
TyburnRR@cs.com
PostPosted: Fri Jan 16, 2004 4:32 am
try:
http://www.unityrailway.com/
PostPosted: Fri Jan 16, 2004 6:52 am
Hennessey pads are no longer available - for some years now. Along with other fallen flags of lube pads including Atlas, Premier, Journapack. The pads from Unity are like wooly sheep, with foam packing inside the sewn cloth bag and are available pre oiled or dry. We like them dry since the oil seems to start the clock ticking on the foam breaking down and disintegrating. It is a little more work to install the dry pad and you have to keep topping up the journal as the initial oil is absorbed, but the shelf life of a new pad is much greater. Only certain 'standard' sizes are available so we continue to wind wool yarn into 'waste bundles' and hand pack journals on some equipment.
Bob Kutella
68trolley@comcast.net
PostPosted: Fri Jan 16, 2004 10:36 am
It is a
You may want to read the AAR Lubrication Manual. It has instructions on soaking new pads before installation. It's important that the fibers are saturated with oil before you put pressure on them otherwise you may not get good lubrication across the whole pad.
pfdx@aol.com
PostPosted: Fri Jan 16, 2004 3:39 pm
> some years now.
Mike Hennessy just returned my call. He closed the Railway Parts business in 1995, and is now a consultant in the same town, Chambersburg, Pa.
> sewn cloth bag
So, that's why we liked Hennessy's product better - Unity's disintegrated for NHIR, also!
TyburnRR@cs.com
PostPosted: Sat Jan 17, 2004 8:09 am
> whole pad.
Well, we do soak and squeeze new dry pads before installing, maybe even starting the day before. I took that as a given, and did not mean to omit that step. That is what I referred to as being more work with the use of a dry pad.
Bob Kutella
