It is currently Mon Oct 26, 2026 10:18 am
 Post subject: 652 eastbound
PostPosted: Wed Dec 24, 2003 5:55 pm
Rocky Mountain Rocket eastbound out of Limon, Colorado in the 1960s. Tired-looking lead unit 652 would be the only CRI&P E unit saved. Today it is nicely restored in eastern Kansas, and save for a freight style pilot added after a wreck in the late-1950s, looks as good as when it rolled out of LaGrange.
http://photoswest.org:8080/cgi-bin/cw_cgi?fullRecord+11800+594+780112+93+0
ryarger@rypn.org
 Post subject: Re: 652 eastbound
PostPosted: Wed Dec 24, 2003 6:03 pm
> eastern Kansas.
Hey Bob,
The 652 was not the only CRIP E unit preserved. Unit 630, a slant-nose E-6, is under restoration at the same location in Kansas.
Dan
dan-rohrback@cox.net
 Post subject: Older sister 630
PostPosted: Wed Dec 24, 2003 6:04 pm
A 1942 shot near Limon with the 630, which was also saved (652 was the only newer E saved). The 630 is at the same museum, but needs a lot of work to look and run like this again.
http://photoswest.org/cgi-bin/imager?00005909+OP-5909
ryarger@rypn.org
 Post subject: Re: Older sister 630
PostPosted: Thu Dec 25, 2003 2:34 am
> this again.
The 630 was repainted back to this passenger scheme in 1988, I believe, and then displayed at Topeka Railroad Days that year. She does currently need some cosmetic work, but she is still a pretty old gal. While not able to power her own way, she is set up now as a cab control unit and can be m.u.'ed to our railway's other locomotives. It's odd to run her as cab control with no noise coming from the engine room(whisper cab:), you have to lean out the window to hear if the other locomotives are revving up when you notch out on the throttle. She also retains her #22 brake stand, which I understand is very rare these days.
http://midland-ry.org/midland/images/engines/RI_630.jpg
