It is currently Sat Nov 28, 2026 12:57 pm
 Post subject: Edgewood, MD Flying Point Park Locomotive?
PostPosted: Thu Aug 22, 2019 9:19 am
Hi Everyone. I'm interested in the whereabouts of a one-off park steam locomotive/coach that operated at Flying Point Park in Edgewood, MD for some time... perhaps up until the late 80's?
For reference, here is the location... some of the roadbed is still visible:
https://www.google.com/maps/@39.4411411 ... a=!3m1!1e3
I've tried searching google, rypn itself and locomotive.com and can't seem to find this engine. I believe it was either a 12" or 15" gauge home-built by someone in Churchville, MD. Very curious to know where it went after the railroad closed up shop at the park.
Thanks very much,
Joe
 Post subject: Re: Edgewood, MD Flying Point Park Locomotive?
PostPosted: Thu Aug 22, 2019 11:17 am
Wow, I was stationed at Aberdeen when the Ordnance Center was still there (in the late 90s) and spent time at Edgewood Arsenal in training, and I'd never heard of that until just now.
I'd love to know more about this!
Lee Bishop
PostPosted: Thu Aug 22, 2019 11:44 am
You owe this ID to the Md. Rail Heritage Library, which has a dozen or so photos of this loco by the late Walter Merkle taken in September 1977. Builder's plate was on the side of the cab, as seen in the overall photo.
PM/e-mail me if you want more.
Elk Valley RR 4, Flying Point Park, MD, 9-77; by Walter Merkle, MRHL Coll. (2).jpg
Elk Valley RR 4, Flying Point Park, MD, 9-77; by Walter Merkle, MRHL Coll. (2).jpg [ 237.06 KiB | Viewed 63274 times ]
Elk Valley RR 4, Flying Point Park, MD, 9-77; by Walter Merkle, MRHL Coll. (12).jpg
Elk Valley RR 4, Flying Point Park, MD, 9-77; by Walter Merkle, MRHL Coll. (12).jpg [ 194.03 KiB | Viewed 63274 times ]
PostPosted: Thu Aug 22, 2019 2:14 pm
PM sent. Thanks very much for the reply!
I recall it being an unusual wheel arrangement for a park loco... not just the typical Cagney/Ottaway 4-4-0. Super interesting.
Any clue where it might have gone?
Thanks again,
Joe
PostPosted: Thu Aug 22, 2019 3:09 pm
Looks like Southern or Young valve gear. I'm no expert on how to ID either of these but this looks like it could be one of them. Wheel arrangement appears to be that of a 2-6-2.
Rob Gardner
PostPosted: Thu Aug 22, 2019 3:37 pm
More info here.
https://books.google.com/books?id=Tp3IaVYwzaUC&pg=PA109&lpg=PA109&dq=%22flying+point+park%22+train&source=bl&ots=8h_WSIOa8i&sig=ACfU3U09cCRoEtaUZFBsQNh5bt5_chfxLA&hl=en&sa=X&ved=2ahUKEwiA1bHYm5fkAhVLq1kKHXemDrYQ6AEwFHoECAkQAQ#v=onepage&q=%22flying%20point%20park%22%20train&f=false
The train was sold by the County between 1995 and 2002.
PostPosted: Fri Aug 23, 2019 8:47 am
Ah! Thanks very much! It must have been 1984/85 when I rode it. I was a kid at the time.
Humm... I'm sure Harford county still has the sale records, now, if I could just figure out who to talk to. ;) Thanks again for the info.
-Joe
PostPosted: Fri Aug 23, 2019 8:33 pm
Richard Herbig at the Harford county historical society. He was or is a county attorney, preservationist and helped save the b and o station in Aberdeen
PostPosted: Sun Aug 25, 2019 5:21 pm
Why does the builder plate say "1985"?
PostPosted: Sun Aug 25, 2019 6:55 pm
It doesn't. A stray spot of paint, corrosion, or dirt makes it possibly LOOK like "1985," but this loco was built in 1965 and the photos taken in 1977.
PostPosted: Mon Aug 26, 2019 8:59 am
Thank you Bobulltech, I'll try to find Richard Herbig and reach out.
I contacted the Harford county parks and rec director on Friday. She was very nice, and offered to forward my question to someone else in their office who might now.
Thanks again for your help, everyone.
-Joe
PostPosted: Mon Aug 26, 2019 8:10 pm
Hi all
The locomotive valve gear is known as a Hackworth type valve gear.
Hackworth valve gear
From Wikipedia, the free encyclopedia
Jump to navigation
Jump to search
Hackworth valve gear on steam locomotive 'Lydia' at the Perrygrove Railway.
Hackworth valve gear on Tal-y-Llyn Railway 'Edward Thomas'
The Hackworth valve gear is a design of valve gear used to regulate the flow of steam to the pistons in steam engines. It is a radial gear, with an actuating lever driven from the crank. The drive may be taken directly from the crank (top picture) or indirectly via a return crank (lower picture). The other end of the actuating lever is attached to a die block which slides in a slotted link. When the link is vertical, the engine is in mid-gear. Forward, reverse and cut-off adjustments are made by moving the link away from the vertical. The valve rod is pivoted to a point on the actuating lever.[1]
PostPosted: Wed Aug 12, 2026 1:29 pm
Bringing this thread back from the dead. :)
I ended up speaking with some of the Duncan family (via Facebook) about 7 years ago asking where the engine had ended up.
The most info I had found is that it had gone to a "private estate railroad in Western Pa".
This mystery still pops up in my head every once and awhile... does anyone know of any private railroad that might fit this description?
I don't know the exact gauge, but I'm thinking somewhere from 12" to 16"
Thanks,
Joe
PostPosted: Wed Aug 12, 2026 2:05 pm
Bucksgahuda & Western, maybe?
PostPosted: Thu Aug 13, 2026 10:48 am
I'll reach out to those folks and see what I can find. Based on searching for that railroad, there was also one called the Teaberry and Southern nearby? That might be a good lead too. I'll post my findings. :)
