It is currently Fri Oct 16, 2026 3:01 am
 Post subject: Posting photos to interchange
PostPosted: Sat May 24, 2025 10:47 am
I want to suggest that someone who knows could pin an announcement about posting photos to Interchange as to proper sizing, so they don't get posted way oversize, which frequently happens. I went looking for guidance this morning and could not find any here. Also, when I tried to upload a photo, the progress bar just kept running and never completing. Thanks.
 Post subject: Re: Posting photos to interchange
PostPosted: Sat May 24, 2025 3:21 pm
viewtopic.php?f=1&t=48359
I would add to the instructions in my reply that the maximum dimension is 1024 on RyPN, so I usually set my largest dimension as 1023 when resizing.
PostPosted: Sat May 24, 2025 3:51 pm
Thank you.
PostPosted: Sun May 25, 2025 11:40 am
If it helps, I post images at 800x600 pixels or thereabout at 72dpi. I think you can go as high as 1024x768 at 72dpi. They'll post at a smaller size and will be displayed a bit larger when you click/tap on it. IIRC, the max file size limit is 350K.
