It is currently Wed Aug 26, 2026 8:00 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: angle cock lubricant
PostPosted: Thu Jan 09, 2025 12:52 am
A followup: I recently did an older 1-1/4 angle cock with conventional tapered brass plug key.
After lapping, I lubricated with Lubriplate 130-A. This is a calcium sulfonate grease, NLGI between 2 and 3, and has a zinc additive. The manufacturer recommended it as having excellent compatibility with brass and bronze, and having excellent tackiness and anti-washout properties. I mixed in a small amount of dry graphite. So far I'm pleased with the results. I guess we'll see how it holds up after a year.
PostPosted: Thu Jan 09, 2025 9:37 am
I've been wondering while following this thread: Is there any concern with with stray lubricants gumming up brake valves?
PostPosted: Fri Jan 10, 2025 11:43 pm
If the lubricant is applied excessively, I can see it migrating into the ports when the key is rotated. But the same properties which make it desirable as a plug key lubricant, the tackiness, adhesion, and wash-down resistance, would also make it unlikely that the small amount of lubricant which actually remains in between the two metal surfaces would migrate downstream.
PostPosted: Sun Jan 12, 2025 11:29 pm
Go to a plumkbing supply and buy a small tin of silicon stopcock grease. It should work.
PostPosted: Mon Jan 13, 2025 5:08 pm
That's what the Molykote grease I mentioned earlier is. A silicone grease with NLGI between 3 and 4.
I'm going to do a "bake-off" next and try lubricating the same 1/2" cutout/drain cock with various greases to see what works the best.
