It is currently Sat Nov 28, 2026 12:55 pm
 Post subject: Brake components needed, 45/50 ton GE
PostPosted: Thu Dec 12, 2024 4:31 pm
Good Afternoon. I've begun the process of replacing a couple of brake cylinder cups on our 50 tonner (chain-drive version as opposed to siderod). Do those of you who operate them have a reliable source for cups and brake shoes? I used to get shoes from Birmingham Rail but they're supposedly gone. I don't have the brake cylinders apart yet. Is there anything special about the cups or are they a standard size? Any help is appreciated in order to help speed up the process.
Andrew Durden
Chief Mechanical Officer
Southeastern Railway Museum
 Post subject: Re: Brake components needed, 45/50 ton GE
PostPosted: Thu Dec 12, 2024 7:14 pm
I've never used Birmingham Rail, but their web site looks like they are still there:
https://bhamrail.com/locomotive/parts/
PostPosted: Fri Dec 13, 2024 10:18 am
Don't forget McHugh either, they'd done some pretty impressive stuff and worked with museums and excursion operations.
https://www.mchughlocomotive.com/
PostPosted: Wed Dec 18, 2024 4:26 pm
The really old ones have a leather/rubber ring bolted on the piston. Newer ones use cups. I have a pile of cups if you need them. The rings we got for Spencer's 25tonner from Multiservice Supply I believe, I can check on that.
Adam McDowell
Owner ATOM Rail LLC
