It is currently Sat Jul 05, 2025 4:50 am
 Post subject: question on a rr.
PostPosted: Thu Oct 10, 2024 8:37 am
I have a rr hand lantern that is marked WNRR. I can't find the rr located, can any one please help in identifying it? toot.
 Post subject: Re: question on a rr.
PostPosted: Thu Oct 10, 2024 10:55 am
i may sound like a broken recorded on this subject but pictures do help others identify things for you
goodluck
PostPosted: Thu Oct 10, 2024 2:35 pm
as I have stated before. I am not able to post pictures of items on my humble laptop. sorry, if I could I would do it. hope you understand? thanks' for the help.
PostPosted: Fri Oct 11, 2024 12:41 am
A lot of laptops in the past decade or more come with webcams built in.......
PostPosted: Fri Oct 11, 2024 7:03 am
maybe mine has it. but at 80 +++yrs old I have all I can do to turn it on & off, LOL. in other words I don't know how to navigate through it. sorry I thought that putting the initial's stamped on the shackle was enough?
PostPosted: Wed Oct 16, 2024 6:35 am
well I found it. the RR is the WISCONSIN NORTHERN RAILROAD. TOOT.
PostPosted: Fri Oct 18, 2024 9:29 am
I think part of the lack of response was due to an assumption that your lamp was an antique.
Wisconsin Northern has only existed as a 'thing' since 2004, and it is a property operated by Progressive Rail (along with some other shortlines, including what used to be the Dan Patch).
Prior to 2004 its operations involved the Soo and Wisconsin Central, neither of which I'd think would be likely to stamp their lanterns 'WN'.
You might be able to verify that this lantern was sourced by Progressive by asking them directly:
(888) PRO-RAIL [776-7245]
pgrcs@progressiverail.com
PostPosted: Sat Oct 19, 2024 7:22 am
overmod, thank you so much for the great info you supplied to me. so maybe the WC stamping on the lantern is not the WISCONSEN CENTRAL. and another rr that I cannot find. it makes sense that as a new rr line that they would not stamp or use these lanterns? then there has to be another RR that was WC. I;LL keep looking.
PostPosted: Sat Oct 19, 2024 3:21 pm
WNRR could be Wharton & Northern. It was taken over by CNJ in the 1920s.
PostPosted: Sun Oct 20, 2024 7:25 am
Eric, thank you for the reply. now it definitely is some what beat up and is definitely stamped WNRR, and old. so what you say makes sense, that it was a WARTON & NORTHERN RR. lantern, used after the merger, take over and not discarded. if it ain't broke don't fix it. again thank you.
PostPosted: Sun Oct 20, 2024 7:59 am
Eric, I just google searched WARTON & NORTHERN RR, and a wealth of info came up on it. without your help I never would have found out about the RR. thanks' again. that is what makes this site great.
PostPosted: Thu Oct 24, 2024 8:57 pm
W&N could also be Wilmington and Northern, between Reading PA and Wilmington DE. later part of Philadelphia and Reading and Reading Company. The portion between Coatesville and Wilmington is still in service.
Users browsing this forum: No registered users and 81 guests
cron
