It is currently Sat Oct 17, 2026 12:06 am
 Post subject: New steam insanity - again
PostPosted: Wed Jun 19, 2024 8:07 am
It's amazing what people can get funded - and here I am struggling to get funding for my research
https://www.globalrailwayreview.com/news/174246/steamology-zero-emission-steam/
 Post subject: Re: New steam insanity - again
PostPosted: Wed Jun 19, 2024 9:49 am
What's supposed to be wrong with this?
While it does remain to be seen if the implementation is practical, there is nothing weird about either the steam generation or consumption...
PostPosted: Wed Jun 19, 2024 10:00 am
It would be very ironic if, in the search for zero emissions locomotives, we went back to steam.
cv the civil E in NJ
PostPosted: Wed Jun 19, 2024 2:40 pm
The issue with this idea is how the hydrogen fuel is obtained. The only "zero emissions" methodology I know of to extract hydrogen is to power electrolysis with nuclear energy or hydro/wind power. Otherwise, once again, this becomes a case of simply moving the emissions smokestack from the vehicle to a production plant. In the same way, rail electrification only becomes "zero emissions" if powered by nuclear or hydroelectric power (see the PRR's power dam across the Susquehanna, the Milwaukee Road's hydro power plants, etc.).
PostPosted: Wed Jun 19, 2024 5:46 pm
In my opinion, the 'hydrogen' part of it isn't going to be workable long-term; the majority of the issue with hydrogen carrier has been with the supply infrastructure and long-term price assurance -- and there was a far better case for that with the Coradia iLINT battery trains and their ilk than there ever would be for something burning hydrogen in a steam generator (rather than in, say, ceramic turbines for GTCC with steam bottoming).
I've said it before; I'll say it again: the only long-term source of hydrogen carrier that makes any sense whatsoever is blue hydrogen with sequestration. Yes, it's like the first law of consulting.
PostPosted: Thu Jun 20, 2024 11:08 am
Hydrogen, the gleam in the eye of well meaning, motivated and clueless people who do not know basic fundamental engineering facts. Hydrogen, poor energy density, explosive, likes to leak, study hydrogen embrittlement of steel. Why look for trouble, here it is.
PostPosted: Thu Jun 20, 2024 11:41 am
An acquaintance and former minor Milwaukee Road official was wont to praise the electrification, considering it to have been a step in the right direction that had the misfortune to be shackled to the rest of the railroad.
As an aside, he once made the observation that the only truly clean building he ever walked into on the property was a generating station.
PostPosted: Thu Jun 20, 2024 11:16 pm
Safe Harbor dam, on the Susquehanna between Harrisburg and Columbia, still has two turbines generating 25 Hz power for Amtrak.
P
PostPosted: Thu Jun 20, 2024 11:33 pm
Where is 25 cycle power still being used?
Is it converted to 60 cycle power somewhere, or are there GG1's operating in hyperspace?
PostPosted: Fri Jun 21, 2024 12:04 am
With due respect another "really clean" power source is geothermal. There are some new technologies becoming available to deep drill laterally (developed in the fracking industry) which have the (imho REAL) potential for geothermal to become very efficient. Again with apologies to further drift this subject, If there is still enough western land grant lands on the UP and NP routes this could become a cheap source of electricity to electrify both the BNSF and UP mains.
PostPosted: Fri Jun 21, 2024 7:51 am
I'm away from my timetable, but IIRC the cutover is somewhere on the Hellgate Line.
Everything south and west on the ex-PRR is still 25 cycle.
Corrections welcome.
Brian Helfrich
PostPosted: Sat Jun 22, 2024 11:24 pm
Pretty much Amtrak's entire ex-PRR electrification is 25 Hz. The phase break is near "GATE" on the Penn Station end of the Hell Gate Line. SEPTA's ex-PRR lines use this power also.
SEPTA's ex-Reading lines also use 25 Hz power but supplied by PECO at 60 Hz to a frequency changer at Wayne Junction. The phase break is at Spring Garden St. where the Center City Tunnel joins the ex-RDG trunk.
NJT's ex-DL&W Morris and Essex lines were re-electrified at 60 Hz. On their way to Hoboken they cross above Amtrak's ex-PRR "High Line" at "SWIFT" where there are ramps and connections with phase breaks. Not all equipment is compatible with both frequencies and NJT has to be careful what they send where.
At NJT's Secaucus Jct. there is no track connection and NJT's ex-Erie track is not electrified.
PostPosted: Sun Jun 23, 2024 5:53 pm
Somebody needs to figure out how to harness the energy in those volcanos up in Iceland.
/s/ Larry
Lawrence G. Lovejoy, P.E.
PostPosted: Sun Jun 23, 2024 7:12 pm
Minor correction. The Ex DL&W tracks go under the Ex PRR track's and the ramp tracks go up to the High Line at Swift.
You may have heard of plans to replace the "Sawtooth Bridge."
That's the bridge structures over the Ex DL&W tracks.
Brian Helfrich
PostPosted: Mon Jun 24, 2024 11:01 am
For reference, their steam generators (of which there are 20 in the test mule) use green hydrogen and "02" as "fuel". They raise steam in "<10 sec" which indicates they are using a flash arrangement -- perhaps not the best if there is long-term embrittlement or corrosion. It would be interesting to see if modern fabrication techniques have reduced the cost of a tapered monotube in alloys that will support their claimed 46bar pressure.
They indicate that a module can produce "up to 600kg/hr." but don't specify the pressure or any degree of practical superheat in delivered steam at that mass flow. More significantly, perhaps, with hydrogen storage of only 140kg, I wonder what the effective range of the locomotive at its peak 2MW output would be.
One notes, in the 'collateral', a claim that this approach (e.g. 20 generator modules feeding four turboalternators) represents a higher energy density, more cost-effective operation and lower overall cost over the locomotive's lifecycle, compared to 'batter' or 'fuel-cell' alternatives (presumably of equal power, flexibility, and availability). The whole approach will 'sink or swim' on a practical generation and distribution architecture for carrier hydrogen, which of course would be necessary for fuel-cell or battery-recharge 'solutions' too, and this has apparently not gone as well as promoted for the Coradia iLINT and other battery-train schemes in Europe. Much of the anticipated use of 'green hydrogen' in Britain is at comparatively low pressure (as for town gas) and this would require electric compression, perhaps to 3000psi or higher, and perhaps liquification, to be used for 'transport' applications.
Contact information, for those interested in better details:
Steamology
The Boiler House, unit 19,
Dean Hill Park,
West Dean,
Nr Salisbury,
SP5 1EZ
+44 (0) 1794 463 366
+44 (0) 1794 463 367
info@steamology.co
