It is currently Fri Oct 16, 2026 11:42 pm
 Post subject: EMD SW1 roots blower filter
PostPosted: Fri Apr 26, 2024 10:03 pm
Hey y’all!
Hoping someone can help me here. I have poured all over the 090 and 300 catalogs for the roots blower filter on an SW1 and I can’t find it to save my life. It’s driven me bonkers for the last hour and a half too. Could someone help me with my quest?
The reason I am seeking this part is, I did an initial inspection on an SW1 that our organization may be acquiring. It needs some work, nothing too crazy, however this part was the only missing piece.
I appreciate any help that can be offered.
Gary Rodriguez
SA, TX
 Post subject: Re: EMD SW1 roots blower filter
PostPosted: Fri Apr 26, 2024 10:15 pm
Sorry, I forgot the photo of the location for the part in question.
Gary Rodriguez
SA, TX
File comment: Photo of the location of the missing filter canister(?).
PostPosted: Fri Apr 26, 2024 11:22 pm
Original circular blower mounted filter was usually 8050846.
PC
PostPosted: Fri Apr 26, 2024 11:36 pm
PC
Where can I find one and which catalog should I refer to? TIA
Gary Rodriguez
SA, TX
PostPosted: Sat Apr 27, 2024 12:09 am
Catalog 301, List A378. I doubt EMD has any, it would be a scrap/salvage item now.
An SW1 uses one filter, an NW2 uses two of them. Farr marketed a rectangular replacement unit many years ago. If you want to adapt a currently produced air filter a 6-567 engine requires about 1800 CFM air flow.
PC
PostPosted: Mon Apr 29, 2024 9:08 pm
I'd suggest doing a little shopping for the adapter to run a Clark "small baggie" filter. I can't remember if that's the EG-1 or EG-2 part number. Both our SW-1s have them. Fairly common and available in an extended life version as well.
PostPosted: Tue Apr 30, 2024 11:30 am
I scrapped/parted out an EMD SW9 that had an air filter that used a round long heavy equipment filter you could just purchase at any Napa store.
The SW9 had 2 of these.
A lot of the older locomotives originally used an oil bath filter.
PostPosted: Tue May 07, 2024 4:04 pm
Would you happen to know where you get the filters? I dealt with Clark in the past, but apparently they were bought out by someone else.
TIA
Gary Rodriguez
SA, TX
