It is currently Sat Oct 17, 2026 1:44 am
 Post subject: Erie Lackawanna EMD Locomotive Clearance Features
PostPosted: Sat Apr 06, 2024 7:23 pm
The EL had some special clearance features on their EMD SD locomotives:
Unusual air horn mounting in front of the right side number boards
Low profile fans
Low profile inertial filter compartment hatch
Low profile truck suspension components
As participants at another discussion asked me why these were required, I am sharing that information here. These features were needed due to clearance problems on the DL&W lines in New Jersey, particularly low wire on the electrified lines in hot weather, at Summit Station and some other locations. The strike zone was directly down the centerline of the locomotive. We had a clearance alarm at the Marion Shop to monitor the height of roof fixtures.
PC
 Post subject: Re: Erie Lackawanna EMD Locomotive Clearance Features
PostPosted: Mon Apr 08, 2024 10:36 am
Good info Preston. I always figured that was the reason. I remember hearing that there was a low spot in the Cleveland area also, is this true?
PostPosted: Mon Apr 08, 2024 6:49 pm
Yes, there was also a restriction in Cleveland where the larger profiles could not pass.
Here are down-on views showing the low profile features. Compare the SD45 fans with the GP35 fans in the top photo.
PC
ELRR-3621-SD45-TWILIGHT-MARION-OHIO-JUL74-P-COOK.jpg [ 98.19 KiB | Viewed 5666 times ]
PostPosted: Thu Apr 18, 2024 11:13 am
They had to raise the frames on the 45's to get those big fuel tanks under there...
