It is currently Sat Oct 17, 2026 4:53 am
 Post subject: Auspicious Anniversary: First US Coal Burning Locomotive
PostPosted: Mon Feb 19, 2024 3:12 pm
Courtesy of the Cassel mailing list:
The first practical US coal-burning locomotive made its' first trial run in Pennsylvania - 19 February 1831
Unfortunately, it would later kill its inventor
In 1831, the York locomotive made its first trial run. Though it was not the first to be invented, it was in service for several years, and is regarded as the first practical coal-burning locomotive built in America. It was designed with a vertical boiler by Phineas Davis for the B&O Railroad competition for inventors, which it won, and was adopted by the B&O. The name comes from York, Pennsylvania, where it was built and tested. It was the first locomotive constructed with coupled wheels and two pairs of drivers. The wheels were 30 inches diameter, and the engine weight was 3½ tons. On 27 September 1835, while on an excursion for employees, Phineas Davis, was on board the locomotive observing its operation when the train derailed due to defective track, and Davis died in the accident.
 Post subject: Re: Auspicious Anniversary: First US Coal Burning Locomotive
PostPosted: Mon Feb 19, 2024 7:07 pm
Last edited by Kelly Anderson on Sun Aug 18, 2024 8:19 pm, edited 1 time in total.
PostPosted: Mon Feb 19, 2024 9:07 pm
Gowan and Marx -- equalized driving wheelbase further three-point equalized with a four-wheel leading truck. 1839.
PostPosted: Mon Feb 19, 2024 9:14 pm
Last edited by Kelly Anderson on Sun Aug 18, 2024 8:18 pm, edited 1 time in total.
PostPosted: Mon Feb 19, 2024 10:27 pm
Eastwick's original patent was November 20, 1837, but it was not fully practicable in that form. Harrison's patent is more workable, April 20 1838.
Unfortunately I do not know the time at which the Patent Office granted these.
PostPosted: Tue Feb 20, 2024 11:42 pm
What if the track defect was a snake. Wouldn't that be a problem even if there was equalizing gear.
PostPosted: Wed Feb 21, 2024 8:10 am
There was an interesting documentary about early coal burning steam made in the silent era called OUR HOSPITALITY. Worth a look.
PostPosted: Wed Feb 21, 2024 7:04 pm
"What if the track defect was a snake. Wouldn't that be a problem even if there was equalizing gear."
I presume you mean a 'snakehead', lifting of a strap rail far enough that a wheel 'picks' it.
Not an issue for equalization in weight distribution, and less likely that drivers will strip it: it will either be picked at the lead axle, or by one of the coaches following (where its chief danger is penetrating and disrupting the relatively lightweight wood construction -- it doesn't help if the trucks use something like those Winans antifriction axles with thin little 'journals' and no provision for wheel braking.
