It is currently Sat Oct 17, 2026 5:24 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
 Post subject: Pullman troop sleeper interior colors
PostPosted: Sat Nov 14, 2020 1:45 pm
What were the correct interior paint colors for the troop sleepers?
Behind the layers of white paint on our car we are finding a brown.
Thanks
Bill
 Post subject: Re: Pullman troop sleeper interior colors
PostPosted: Sat Nov 14, 2020 6:39 pm
We found a light brown at the bottom of the layers too. The Pullman Library should be able to tell you for sure.
PostPosted: Sat Nov 14, 2020 11:37 pm
Thanks!
PostPosted: Sun Nov 15, 2020 4:15 pm
Is yours plywood over tongue in groove?
PostPosted: Mon Jul 10, 2023 7:12 pm
Reviving my own thread.
This is what we found hidden behind some sheet metal the RR installed to protect the wall from from a heater.
PostPosted: Sun Oct 15, 2023 10:51 am
Another thread revival...
Based on the list of files the good folks at the Pullman Library sent me they do not have a bill of materials list for lot 6704 cars, the first group.
So how are or have the other groups been determining the correct paint and other restoration items for the first group of cars?
Thanks
PostPosted: Sun Oct 15, 2023 2:07 pm
The Library of Congress may have a copy of this. I don't know if it covers interior colors of your car.
*** I changed the reference due to a copy/paste error. Here is the one I intended to paste.
55-289 Operation of Railroads Standard Painting, Lettering, and Numbering of Railroad Equipment War Department Jan. 1946 46 p.
Some of the TMs I have seen are essentially copies of the appropriate section of the AAR Manual of Standard and Recommended Practice.
Good luck.
PostPosted: Sun Oct 15, 2023 8:31 pm
Might also check in the Newberry Library Pullman collection -their online resources seem to have a good bit of info on the Troop Sleepers:
https://collections.carli.illinois.edu/ ... term/Troop[*]
John Isaksen
PostPosted: Sun Oct 15, 2023 10:11 pm
Thanks. I bought several of their files on these cars. They have nothing along the lines of a bill of materials though.
PostPosted: Fri Dec 22, 2023 7:21 pm
Following up in case someone else searches for this info.
The good folks at Pullman Library were able to provide a bill of materials for the cars.
The list shows PPG codes 52847 and 52848 for plywood paint. From what I have been able to find those come back as a mint wintergreen and a gray.
The list shows a 52845 light ivory for primer. That looks to be the color I see in interior photos all over the web.
PostPosted: Fri Dec 22, 2023 7:42 pm
CB&Q passenger train/equipment historian, J. W. Schultz's, latest masterpiece is on the CB&Q WWII troop kitchen cars (300 of 'em) that the "Q" modified after the war for service as mail and express cars at their Havelock, NE, car shop.
His narrative refers to the interior being painted "beige".
His work in the latest BRHS "Burlington Bulletin" No. 71 covers not only the Burlington's "jeeps" but also summarizes other carriers, large and small, that picked up surplus troop sleepers and kitchen cars to be repurposed predominately as head end cars but not all were used in that service.
PostPosted: Fri Dec 22, 2023 8:22 pm
I wonder if that is the repurpose color.
PostPosted: Sat Dec 23, 2023 3:54 pm
No, original. Schultz's direct quote concerning the newly constructed cars is: "Car interiors were painted a light beige."
A quote referring to a photo depicted the cars as-rebuilt at Havelock interior colors is: It appears the car's original light beige interior color was retained."
PostPosted: Sat Dec 23, 2023 5:36 pm
Hmm. Our car has light green behind the beige.
PostPosted: Sat Dec 23, 2023 10:41 pm
Bill - curious question: have you seen any samples of those PPG colors? I’m curious if the light green is similar to the run of the mill government “institutional green”. Might be able to find that in the Fed Specs. Since these are interior colors, a PPG dealer should be able to mix samples for you. They may have to consult the lab in Pittsburgh to get the formula close but it might be worth the effort. A actual sample is always best to have for matching. If you need to go to the lab direct, I may be able to help.
The paint that’s on there now is likely an oil base. You’ll have to seal it before you put anything other than oil over top so the new paint stays stuck on.
