It is currently Sun Oct 25, 2026 9:41 pm
 Post subject: Steamtown Derailment pics *NM* *PIC*
PostPosted: Tue Oct 28, 2003 6:56 pm
mcc385@yahoo.com
 Post subject: Re: Steamtown Derailment pic 2 *NM* *PIC*
PostPosted: Tue Oct 28, 2003 6:57 pm
mcc385@yahoo.com
 Post subject: Re: Steamtown Derailment pic 3 *NM* *PIC*
PostPosted: Tue Oct 28, 2003 6:58 pm
mcc385@yahoo.com
PostPosted: Tue Oct 28, 2003 7:15 pm
Did all of the coaches stay up, or did some fall in after the tender????
jasonsobczynski@yahoo.com
PostPosted: Tue Oct 28, 2003 7:55 pm
2 or 3, maybe more did fall after the tender. Don't know how many.
Joshua
Homepage
joshua@joshuakblay.com
PostPosted: Tue Oct 28, 2003 9:12 pm
Did they clean it up that day?
Lima709Jr@aol.com
 Post subject: Re: Steamtown Derailment pics
PostPosted: Tue Oct 28, 2003 9:21 pm
Holy Cow!!! Derailing in that location is like going on the ground in Macy's window (as we say in NYC).
hpincus@mindspring.com
PostPosted: Tue Oct 28, 2003 11:11 pm
From what I understand clean up happened Saturday into late evening (around 11) and resumed the next morning with things back on the track by noon. As far as track repair goes I don't know.
Joshua
Homepage
PostPosted: Tue Oct 28, 2003 11:38 pm
Thanks for the great pics! The 2317 is a great looking engine --- it's so clean and well proportioned. What a beauty!
PostPosted: Wed Oct 29, 2003 9:52 am
Ya know, there's nothing worse than going on the ground, with a train load of passengers. Been there, done that. A few years ago, when the railroad i work for was running excursions, we had just started out from our boarding area with about 200people on board, and one of our units, an ALCO C-425 went on the ground on a curve. Our trailing unit on the other end was able to pull the train clear of the crossing, and get the passengers off....I was one of 2 people that did most of the rerailing (I was even dressed in my conductors uniform while doing this) and managed to get the lead axle of each truck back on the track in about 2 hrs....The boss wanted to load the train up again, and go, but i argued and said that we should at least try to put the unit around first. Good move, it dropped again, we rerailed it, and the trips were cancelled for the rest of that day and sunday morning, until the track was repaired....
Ken Jones
Niagara Falls Railway Museum
digitekfx@kwic.com
 Post subject: Re: Steamtown Derailment pic 1
PostPosted: Wed Oct 29, 2003 10:55 pm
Does anyone know what caused this to happen?
PostPosted: Thu Oct 30, 2003 12:55 am
Well the rail flipped over. Sounds like about the same thing that happened to 1522 some years back just after the "1st" restoration. Lucky in this case that the engine made it over first. Could this have been "caused" by the the driving wheels of the engine (much larger wheels than a diesel rolling over in sequence with the locos rather heavy weight) crossing a weakened section of rail on a curve where most of the engine weight/force was exerted on the outer (in this case right) rail?
PostPosted: Thu Oct 30, 2003 6:02 pm
In the grand scheme of things - this was a minor event and thankfully there were no injuries. Between the D-L and the NPS, everyone worked together to ensure that nothing worse could have happened post-incident.
les@nessman.net
PostPosted: Sat Nov 01, 2003 1:25 am
Well this isn't the first time the 2317 has derailed while it was in service on steamtown. I remember from one of the shop tours that during one of the polar express runs that the lead trucks somehow jumped the rails over a gravel crossing (if i remember right)
PostPosted: Tue Nov 04, 2003 7:07 pm
2317 itself was not derailed, just the tender and subsequent coaches.
Of interest......
Apparently 2317 kept derailing her front truck. It was found that at some point she was equippped with a truck from a CPR hudson, which was not designed for a pacific and therefore was subject to problems. This was fixed and the problem has ceased.
I have never heard a guess when 2317 was equipped with a hudson truck, either during or after her CPR days.
Joshua
Homepage
