It is currently Sat Oct 17, 2026 3:29 am
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Spokane Portland & Seattle - Oregon Electric Caboose #02
PostPosted: Wed Sep 06, 2023 8:27 pm
Assuming OE and SP&S followed the NP, you’d be looking at freight car color - mineral brown/red in 1938. I don’t think bright red came in until the 50s. Though as I said, I’m not an expert on NP and subsidiaries. I’d contact the NP Historical Society and see what they say.
Never found any trace of brown/red. But those boards could have been entirely replaced over the last 117 years. I did find some red on the backside of the marker lamp brackets.
PostPosted: Fri Sep 08, 2023 3:51 pm
Siding is going up today. We're using TruExterior poly-ash siding and affixing it with stainless ringshank nails.
PostPosted: Fri Sep 08, 2023 11:42 pm
We went through all the siding they had in stock. More on order.
PostPosted: Sun Sep 10, 2023 1:28 pm
I found these items in the caboose before we demo'd it. Any idea as to what they are? The one on the right looks like a socket for large square headed bolts.
 Post subject: Spokane Portland & Seattle - Oregon Electric Caboose #026 -
PostPosted: Thu Sep 14, 2023 11:36 am
Working on recreating the brake piping, valves and gauges. I have the brake valve that was mounted on the rear of the caboose.
This valve was mounted on the forward wall.
I'm assuming the small line fed the brake gauge in the cupola.
Not sure what was connected to this fitting? A brake valve for the cupola?
PostPosted: Thu Sep 14, 2023 3:37 pm
I can’t tell from the photo but the valve on the end in the first photo is probably the retainer. The small line in the second and third photos is for the air gauge. The ball valve in photo 2 is likely an emergency dump. The mystery fitting may have been for a brake valve. Those are my best guesses. All except maybe the retainer are almost certainly not original.
PostPosted: Thu Sep 14, 2023 10:33 pm
Thanks Eric. I've got a gauge coming. The retaining valve has 3 positions marked "LP", HP" and "EX".
PostPosted: Fri Sep 15, 2023 9:22 pm
Door jams are installed and 3 sides are sided.
PostPosted: Fri Oct 13, 2023 9:06 pm
We got our doors finished and installed today. I think they turned out great!
PostPosted: Sat Oct 14, 2023 4:03 pm
In your picture the rollers on the left are from truck side bearings. The other item doesn't look familiar to me. I was stationed for a year in Astoria on the Coast Guard buoy tender Iris in engineering and rescue swimmer. It was 1982 and the BN local still came to the plywood mill there. What a beautiful area!
PostPosted: Sat Oct 14, 2023 7:28 pm
I think you’re right on the rollers - they’re about the right size.
Patrick - In case you or others didn’t know, the retainer markings are for Low Pressure, High Pressure and Exhaust
PostPosted: Sat Oct 14, 2023 11:08 pm
Found this pressure gauge on eBay. Apparently it came out of the Tacoma steam plant. Took it apart and repainted the numbers. Sand blasted the case and scotchbrited the bezel. Got the case painted and the brass clear coated. Will get everything assembled tomorrow.
PostPosted: Sat Oct 14, 2023 11:16 pm
Thanks for the ID. I think the bearings will make good paper weights! I think the one on the right is a socket for track joiner nuts.
It is a beautiful area here! We love it. I’ve got a good friend who is currently stationed with the Coast Guard here. I’m a retired Navy CWO.
PostPosted: Sat Oct 14, 2023 11:19 pm
So low and high brake pressure and exhaust to release the brakes?
I’m going to remount and pipe the valve, but any brakes are long gone.
PostPosted: Sun Oct 15, 2023 8:36 am
Retainers would have been used on long, steep descending grades. They’re a kind of check valve. “Turning up” the retainer will hold a certain amount of air in the brake cylinder keeping the brakes on the car applied when the engineer puts the automatic brake valve in release to recharge the brake pipe so he doesn’t run out of air and have a runaway. You’d stop before the down grade, the brakemen will set as many retainers as needed in either low or high pressure and at the bottom, reverse the procedure. It’s labor and time intensive so not used much anymore since the introduction of dynamic braking on diesels.
If you listen carefully, you can hear the brake cylinder air exhausting out of the retainer when the brakes are released.
