It is currently Sun Oct 18, 2026 12:17 am
 Post subject: Brake Rigging Rod Alloy
PostPosted: Sat Jul 01, 2023 4:07 pm
Another brake question. It never ends…. But at least I’m learning as I go. The Pullman I’ve been working on broke a brake rigging rod. Apparently cracked sometime and finally broke. Is there a specific alloy for the round bar? Rod is slightly bent so weld-on splice likely won’t do, at least in my book.
 Post subject: Re: Brake Rigging Rod Alloy
PostPosted: Sat Jul 01, 2023 4:50 pm
Last edited by Kelly Anderson on Sun Aug 18, 2024 9:27 pm, edited 1 time in total.
PostPosted: Sat Jul 01, 2023 5:25 pm
Well, we had an old brake rod in our scrap pile, and I cut a slice of it off for what I don't remember. I put it in the lathe, and started turning it, and found a hidden fissure right through the middle!
So I wouldn't put too much confidence in the quality of brake rod material.
PostPosted: Sat Jul 01, 2023 5:30 pm
In my infinite wisdom, I suggest 4140 heat treated...
I am just an old man...
Sammy King
PostPosted: Sat Jul 01, 2023 9:37 pm
This rod looked like it had a longitudinal crack that corroded into some kind of occlusion in the middle. The break didn’t look like a normal break you’d see when steel fractures like that under tension. It was kind of lumpy, almost crystalline. Acquiring a bend in that area didn’t help much, either. So yeah, not a quality piece.
It’s a 1921 vintage car. Don’t know the vintage of the rod.
PostPosted: Sun Jul 02, 2023 2:03 am
The design requirements assume the material will be A-33, wrought iron. The yield strength used in design is 10,000 psi, giving a safety factor of about three. But actual construction these days uses A-36.
PostPosted: Sun Jul 02, 2023 7:01 am
That explains the look of the broken ends. My brain didn’t even think “wrought iron”. If I recall somewhat correctly, it doesn’t like getting bent so that could ultimately explain the failure.
PostPosted: Sun Jul 02, 2023 10:51 am
Expanding on Sammy's post, a major locomotive builder also listed 4140H as being a suitable material for this type of application.
PC
PostPosted: Sun Jul 02, 2023 11:37 am
Last edited by Kelly Anderson on Sun Aug 18, 2024 9:26 pm, edited 1 time in total.
PostPosted: Sun Jul 02, 2023 2:01 pm
After looking up the properties, I’m going to agree with David and Kelly. A36 is common, easy to work with and with the size of these rods - they’re huge compared to freight cars - I don’t see breaking it again unless the welds on the jaws are poor.
Thanks for your responses.
