It is currently Sun Oct 18, 2026 2:58 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: Did someone loose their coach?
PostPosted: Fri Apr 21, 2023 6:14 pm
Preliminary reports that Strasburg lost a coach at speed due to drawbar failure.
They say Mr. Murphy comes in three's and this is number 2....
 Post subject: Re: Did someone loose their coach?
PostPosted: Fri Apr 21, 2023 8:19 pm
A 12:59 PM April 21, 2023 Twitter post with two pictures:
Coupler snapped off at strasburg. No one was hurt
PostPosted: Fri Apr 21, 2023 9:41 pm
That's interesting and potentially a bit ominous. While it's hard to tell from the pictured angle, it looks as if the coupler head broke off at the shank, not as a failed drawbar, which indicates to me that there may have been a long-term stress raising and cracking in the 'invisible' part of the coupler shank, as undetected as the critical component in an Allied Full Cushion truck...
PostPosted: Sat Apr 22, 2023 7:08 am
This is why we make chain. Just another interesting day on the railroad.
PostPosted: Sat Apr 22, 2023 7:42 am
(Like button)
PostPosted: Sat Apr 22, 2023 8:03 am
Safety chains work in live steam to keep a train together, but probably wouldn't hold a full-size car, unless you mean using a chain to tow it back to the shop, which probably would work? Also, this is the sort of occurrence that Mr. Westinghouse's brakes were designed to deal with. Train separates, including air hoses, air goes down, and the whole thing comes to a stop, hopefully without the separated cars on the rear crashing into the head end of the train.
PostPosted: Sat Apr 22, 2023 9:11 am
Wells some of the older wood cars say 1903 vintage had safety chains to be hooked up to the next car. Mid Continents "Duluth" now has safety chains once again. I put them on. MC does not use them on the rare occasions those old wood coaches go for a spin that I am aware of, but the point I make is yes at one time there were chains. I believe they were original to the cars and not added on? Open to corrections.
Glad no one was hurt or serious damage. Another reason to do running brake checks, make sure your air brakes are working properly should you disconnect. Regards, John.
PostPosted: Sat Apr 22, 2023 9:19 am
Also should bail off the engine and work it a little in case the hind end of the train is in danger of running into the head end.
PostPosted: Sat Apr 22, 2023 11:06 am
Frisco is correct. On one of our HICO steam excursions we had a separation caused by a " high/low" action as we went over a road crossing between the 14th. and 15th. car in the 18 car long train.
Thankfully we had a very experienced hogger running who immediately bailed off the engine brake, applied emergency sanders and full throttle so that the head end stopped about 15 car lengths ahead of where the hind end did.
VERY fortunately no one was crossing between those 2 cars as they came apart.
Of all the trips we ran that was the only time we suffered a separation. Thankfully !!!
Ross Rowland
PostPosted: Sat Apr 22, 2023 11:33 am
I don't think Dave was referring to safety chains, as on trailers.
I think he meant "back up, chain the loose car up, and keep on a'runnin'...
PostPosted: Sat Apr 22, 2023 11:35 am
Last edited by Kelly Anderson on Tue Aug 20, 2024 7:12 pm, edited 1 time in total.
PostPosted: Sat Apr 22, 2023 12:37 pm
Brother Murphy (and most of his brothers) live on the railroad...
GME
No case so weak nor cause so harebrained that it cannot be handled for an adequate retainer up front.
PostPosted: Sat Apr 22, 2023 2:08 pm
Kelly Anderson wrote:
I guess the FRA is going to have to mandate more installations of automated drawbar-pin-about-to-fall-out detectors...
Yes, and more installations of automated drawbar-pin-about-to-fall-out detector HELP DESKS, too...
I am just an old man...
Sammy King
 Post subject: Re: Did someone lose their coach?
PostPosted: Sat Apr 22, 2023 3:12 pm
They had better, because if they can't, the mandatory car inspections every trip are going to involve checking the drawbar and knuckle attachments, using the same inspectors they're going to check every inside roller bearing and seal at every carman's inspection.
Hey, at least in theory you could use the death ray and a portable Magnaflux outfit to check the pins after they're pulled for NDT. You'll never, ever get a carman to check every inside bearing, fit, and seal every time. But that is what the House and Senate bills describe...
PostPosted: Sat Apr 22, 2023 7:32 pm
Ex-Reading Company steel coaches on the New Hope & Ivyland RR had chains with hooks, and some of the fittings for them survived after some were converted to electric MU cars.
