It is currently Tue Jul 01, 2025 2:35 am
 Post subject: NORM converts system to pantograph operation
PostPosted: Sat Apr 01, 2023 11:45 pm
The Northern Ohio Railway Museum has revived Cleveland Transit System "Bluebird" single unit car 109 to operation, with pantographs in place.
https://pnaerc.blogspot.com/2023/03/cleveland-transit-system-109-runs.html
 Post subject: Re: NORM converts system to pantograph operation
PostPosted: Sun Apr 02, 2023 10:34 am
It's possible to operate with both pans and poles on the same wire.
PostPosted: Sun Apr 02, 2023 11:51 am
I believe both poles & pantographs can operate on the same system, but adjustments have to be made to the hangers, if I recall. Pittsburgh did for several years as they converted to pantographs, if I recall.
Phil Raynes
PostPosted: Sun Apr 02, 2023 12:44 pm
Correct. Hangers have to be above the contact shoes of the pans and wire frogs need guides to push the pans below the frogs.
PostPosted: Sun Apr 02, 2023 5:41 pm
Another thing is like what the old Sacramento Northern did (and I think that Western Ry Museum did when it re-electrified its old SN r-o-w) is to slowly move the single wire back and forth across the width of the pan contact area. Making the zig-zag over several pole lengths. This eliminates the possibility of wearing a narrow grove in the pan. And the slow movement back and forth does not adversely cause problems with a trolley wheel or slide.
PostPosted: Mon Apr 03, 2023 4:37 pm
Congratulations NORM and your dedicated volunteers who made this possible! Very impressive.
Best wishes,
Matt Nawn
PostPosted: Tue Apr 04, 2023 8:49 pm
I'm assuming NORM adapted the overhead so you can use either poles or pans.
PostPosted: Fri Apr 07, 2023 12:00 am
The overhead at NORM is being built to allow pan and pole operation. It has been that way from day one.
Users browsing this forum: Google [Bot] and 121 guests
