It is currently Sun Oct 18, 2026 10:16 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: OK Staybolts
PostPosted: Mon Dec 19, 2022 11:04 am
Note that Mr. Austin's post includes a method for hammer-testing of flexible staybolts, s different procedure from regular stays. Earlier in the letter is a comment that flexible staybolts may fail a hammer test if the head slightly unseated in the thimble, e.g. from the result of contraction with pressure relieved and the cap insufficiently secured.
PostPosted: Mon Dec 19, 2022 7:17 pm
Flexible Stay-bolts are purposely not seated; "run them "in" so they seat, then back "off" 1/4 Turn.
The Hammer looks like the one I used before it was stolen along with my pyrometer.
PostPosted: Tue Dec 20, 2022 9:55 am
What is the reason to back them off?
Roger
PostPosted: Tue Dec 20, 2022 2:18 pm
When the inner firebox gets hot, it expands, causing the bolts to shift very slightly. The shift is an angular shift for the bolts. The backing off gives the bolts a little bit of slack, so that when hot they are properly tensioned, without over stressing them.
PostPosted: Tue Dec 20, 2022 3:25 pm
Mark, thank you that makes perfect sense.
In a related question, do the ball end of flexible staybolts ever bind into the socket? Given the environment they work in, I would have to think it happens at least occasionally.
Roger
