It is currently Sun Oct 18, 2026 4:56 pm
 Post subject: Steam locomotive lubricants
PostPosted: Thu Dec 08, 2022 9:12 pm
Hi all,
What is everyone using and buying from for side rod Grease, lubricators, steam oil etc
Thanks
This is for a college project my son is working on for business class
 Post subject: Re: Steam locomotive lubricants
PostPosted: Fri Dec 09, 2022 1:08 am
What is a "side rid"?
PostPosted: Fri Dec 09, 2022 8:00 am
I would have guess that was meant to be "side rod".
I'm sure the are exceptions but hard grease seems the norm.
Roger
PostPosted: Fri Dec 09, 2022 10:47 am
Last edited by Kelly Anderson on Mon Aug 26, 2024 12:22 pm, edited 1 time in total.
PostPosted: Fri Dec 09, 2022 11:11 am
The name of the manufacturer escapes me, but PB&J (Pin, Bearing and Journal) oil is also a prime lubricant in my experience.
I second Green Velvet steam oil.
As for hard grease, I don't know who manufacturers it anymore. What we have in stock has lasted us many years.
PostPosted: Fri Dec 09, 2022 12:22 pm
P,B, & J sounds like Texaco Journaltex, a parafin based oil, but I haven't bought any in years. Nowadays there is a synthetic equivalent, but again I can't help with a supplier. Some steam operators have changed over to this type oil for driving boxes and crankpin bearings, rather than hard grease.
Lithium type automotive grease also works for valve gears and the various pins and bushings in the running gear. You can get that at any auto parts store, or some big box stores.
For the air side of an air compressor you want mineral oil.
I am just an old man...
Sammy King
PostPosted: Fri Dec 09, 2022 12:28 pm
BB&J is also supplied By Brennan Oil in Durango.
When repairing a steam locomotive, the answer to; "Where do I start?" is usually easy, the hard one is; "Where do I stop?"
PostPosted: Fri Dec 09, 2022 4:55 pm
This ought to help. This is a company based out of Cincinnati, Ohio. They list all the different oils and lubrications that they have, including a description of what they’re used for. https://www.interlubecorp.com/industry/railroad/
Bret Evanich
PostPosted: Fri Dec 09, 2022 10:31 pm
I haven't had to buy any in some time, but I was getting soda-based hard grease for rod bearings from Opti-Lube.
PostPosted: Sat Dec 10, 2022 12:42 am
If you use automotive/off road grease, stay away from those containing Moly, it will corrode bronze bearings.
PostPosted: Sat Dec 10, 2022 8:17 am
A little thread drift….
Same goes for graphite and Teflon or any solid additives. They’re not so much corrosive themselves but they generally don’t play well with water and can clog things up. And they can be abrasive under high pressure which is the exact opposite of what you’re wanting to achieve. In my mind, they’re maybe OK in loose fitting, non-critical things like hinges or garage door wheels. There really isn’t any point to solid additives except the names sound slippery and they cost more. For general lubrication, lithium grease is the way to go.
PostPosted: Sat Dec 10, 2022 9:47 am
We had excellent results from Interlube Carbonless Air Oil and Steam Cylinder Oil on 1522.
PostPosted: Sun Dec 11, 2022 8:36 am
This is probably a bit off topic, but a few years back, I was given instruction from a lubricants company technical person about the value of modern greases. I had spent too much time trying to track down the old stock, hard, cup greases for my machinery.
This man tuned me in on new "recipes!"
On reciprocating parts, such as connecting rods on antique engines, I tried a product he gave me. It was a modern, soft grease, but he insisted it had "hanging on" abilities beyond anything the old hard greases had. He was correct. Even in the reciprocating connecting rod bearings of an internal combustion engine with manual grease cups, where, over an extended period of continuous operation, heat was transferred back to the bearings, they still ran cool and remained lubricated. The new grease stayed where it was needed, where, often, the older greases simply flew off.
These greases are probably not applicable on locomotive side rods where heavier applications of grease have traditionally been used. Although, it might be worth experimenting -- they can be ordered in bulk. Certainly, for smaller applications, there are modern greases that are superior to the old recipes.
Sadly, none of this stuff is cheap today. I bought a pail (18.9 litres) of 80/90 gear oil yesterday, and with taxes, it was over $140.
https://www.comlubetechnology.com/
PM 2094 grease -- https://www.comlubetechnology.com/products.html
