It is currently Fri Aug 28, 2026 3:01 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Silver Dollar City train derailment...!!!
PostPosted: Fri Oct 28, 2022 11:41 am
Mike Tillger wrote:
Video of derailed train. Truck that is off the end of the ties is probable cause of over turning the cars. I doubt that little engine has enough tractive effort to affect a true stringline. Coaches seem awfully broad for the gauge of track in my opinion.
https://www.facebook.com/gary.eldridge.33865/videos/1469541250223467
Well, the photographic evidence would seem to imply that she does in fact have enough power to stringline the consist. Keep in mind, it's 2 foot gauge, so center of gravity easily becomes an issue. Once the start tilting, not much force needed to keep them going.
Anyone who's spent much time around small scale live steam, like 7-1/2" gauge, has seen this type of thing happen on a routine basis.
PostPosted: Fri Oct 28, 2022 11:43 am
Dennis Storzek wrote:
Randy Gustafson wrote:
Slightly confused on why you would have guard rail on the partial inside rail of a curve.
Guard rails for guidance are normally on the inside of a curve... but this one obviously isn't for guidance, being almost 1/4 of the gauge from the running rail. This guard rail is to contain a derailed wheel, so the truck stays up on the track, rather than letting the car topple down the embankment. Whatever, it was on the wrong side to be of any use in this situation.
Came here to say this. Spaced far to wide to contact the flanges while they're still on the rail. The goal of this one is just like a guard rail on a bridge. If you drop off the rail, you bounce along between the two rails, guiding you in a general direction.
Why only part of the curve? Could be sharper there, or could be that the terrain is steeper, meaning a derailment at that point would be more likely to fall down a hillside.
PostPosted: Fri Oct 28, 2022 11:40 pm
I noticed in the video that there were no center pins between the truck and the carbody. If they had been using locking center pins, the weight of the trucks would have figured into the CG and the cars might have stayed upright.
PostPosted: Sat Oct 29, 2022 7:39 am
It was suggested to me that over the years the trucks on the cars were never turned to run in the opposite direction and uneven flange wear could have been a contributing factor. The term "pizza wheel", for how much flange there was on one side was used.
PostPosted: Sat Oct 29, 2022 9:38 am
It's plain to see in the pictures... "thin flange" is not an issue here.
We'll probably be surprised to learn which car actually derailed first...
PostPosted: Sat Oct 29, 2022 4:17 pm
I'll only be surprised if it isn't the derailed car that's furthest from the loco. Classic stringlining it would appear.
PostPosted: Sat Oct 29, 2022 5:39 pm
Last edited by Kelly Anderson on Mon Aug 26, 2024 12:40 pm, edited 1 time in total.
PostPosted: Sat Oct 29, 2022 8:47 pm
I've watched a lot of video of the Romney, Hythe and Dymchurch over the last few years, and one of the most striking things about it is that they are running 1/3rd scale locomotives on quarter scale track gauge, with cars that are a little larger than that, at speeds up to 30 mph, on stick rail that in some places, under telephoto view looks like the bad old days of Penn Central, and they don't have problems like this. I don't think the problem was necessarily over-size equipment for the gauge. So, probably something happened that we will have to learn about in an investigation. Hopefully it will be independent, thorough and professional.
PostPosted: Sat Oct 29, 2022 10:12 pm
I’ve been a theme park enthusiast myself for a while and I can’t say I’ve ever seen this happen
PostPosted: Sat Oct 29, 2022 10:43 pm
I did catch an interview, which now I can’t seem to find buried amongst all the stories, of a witness that said a car was bouncing up and down right before it went over. That says derailment then tip to me. She may have been in the last car and was referring to the one in front of it - don’t recall The last car didn’t tip. If someone runs across that interview, post the link.
PostPosted: Sun Oct 30, 2022 1:09 am
A couple of issues that I wonder about: does the length of the train or the length of the individual cars have an effect on stringlineing? And the effects of scale on speed, is a 2 foot gauge train going 10 mph the same as a standard gauge train going 20 mph? Side bearing clearances scaled out to standard gauge could be excessive especially when combined with larger than scale width of the cars. Isn't ASTM trying to come up with standards for amusement park rides?
