It is currently Mon Oct 19, 2026 3:15 am
 Post subject: What on earth did we find...?????????
PostPosted: Sat Aug 20, 2022 7:25 pm
Hi guy's, no look on our facebook group, so I will ask over here. Does anyone know what the hell this thing is?? It was found outside of our fence by a detectorist who kindly donated it. The tag with the 1 on it is a bakelight type material. Could it be from a switcher or something or is it off of our 4-8-2 Locomotive???
299378814_10158285786981621_6783311559503808122_n.jpg [ 118.07 KiB | Viewed 8673 times ]
299778043_10158285787016621_3863016358316901437_n.jpg [ 75.43 KiB | Viewed 8675 times ]
From the footplate,
Project 6069
engine6069@hotmail.com
 Post subject: Re: What on earth did we find...?????????
PostPosted: Sat Aug 20, 2022 9:23 pm
What’s the history of your location? That might help with the guesses.
PostPosted: Sat Aug 20, 2022 11:22 pm
If it's CNR 6069, it's a U-1-f 4-8-2 displayed in Sarnia, Ont.
http://www.cnrha.ca/node/704/
PostPosted: Sun Aug 21, 2022 8:31 am
A couple years ago I bought 4 Duff Norton air jacks. Don't remember if I knew where they came out of? But all were tagged and numbered with record of last inspection. These possibly came out of North Fondulac Soo Line shop complex but who knows. I doubt yours came from an air jack but point is it could also of come off of a machine or tool and not necessarily the locomotive? What throws me is the chain so it is interesting to find out what it had been attached too. Good luck on the hunt.
Regards, John
PostPosted: Sun Aug 21, 2022 10:02 am
Thanks guy's not sure what it could be from either and yes it was found near 6069 in Sarnia. It didn't look like anything from the locomotive itself.
From the footplate,
Project 6069
PostPosted: Mon Aug 22, 2022 9:07 am
Rabies vaccination tag?
PostPosted: Tue Aug 23, 2022 9:22 am
That tag has no structural strength. Could this be a security chain, perhaps for a version of blue-lighting or tag/lockout? The chain is hefty for that, but might have been 'repurposed' to save money.
PostPosted: Tue Aug 23, 2022 12:08 pm
That is a tag normally attached to a cows for identification. Marketed as a neck tag.
PostPosted: Tue Aug 23, 2022 9:12 pm
Not sure Overmod? It is a hefty chain hence my thinking railway related
From the footplate,
Project 6069
PostPosted: Wed Aug 24, 2022 9:44 am
It is indeed a hefty chain -- far heftier than the 'weakest link' tag could support; in fact I'd suspect even that chain's weight might damage the tag. On one side, with an unjoined 'cold shut' or opened link through the tag hole.
The chain on the 'bottom' side is much lighter, and is attached with one of those screw-closed light links.
Could it be repurposed load-binding chain, to secure a load or stock of something 'not to be tampered with'?
PostPosted: Wed Aug 24, 2022 1:54 pm
Which means that someone just hung it on the opened link for convenience; it's not part of the rig at all. Meanwhile, the repair link is used to join the ends of two light chains, like would be used to restrain welding tanks. The tag likely indicated when the tanks were changed, or by whom. Either way, not related to the locomotive. I don't even think those quick link repair links date back to the steam days. Anybody know?
PostPosted: Thu Aug 25, 2022 11:50 am
Probably good to identify anything you want, but I see these all the time in boiler rooms, sprinkler rooms, plants, etc, they are hung around the valves and there will be a chart nearby that tells you what each valve does.
PostPosted: Fri Aug 26, 2022 1:32 am
Numbered tags are frequently nailed to trees in forest research plots.
Good practice is to use aluminum tags and nails to prevent damage to saws and sawmill equipment if the trees are ever harvested.
PostPosted: Fri Aug 26, 2022 2:15 pm
I asked about the site’s history as that could help explain what the tag may be for. What was there “way back in the day” prior to moving the locomotive to that particular spot? 1951 aerial shows nothing but a 1930s topo shows a spur there. Could also be just a bit of trash drug there and left in the dirt.
Unless I’m looking in the wrong spot.
PostPosted: Mon Aug 29, 2022 9:39 pm
The spur line is still there as it feeds to the Grain elevators that Cargill own
From the footplate,
Project 6069
