It is currently Sun Oct 25, 2026 6:06 pm
 Post subject: Superheater Boiler Flues
PostPosted: Fri Oct 03, 2003 9:08 am
Hello.
I wanted to poll the readers of RYPN to find out if any of you new of a reliable source for replacement Superheater Boiler Flues. I am seeking 5 1/2" OD x 3/16 x 14' in either SA-172 or SA-192.
I have contacted Anderson as well as the Boiler Tube Company of America.
If anyone has other reliabile sources, please let me know. Thanks in advance for your assistance.
dh
dave@hensarling.org
 Post subject: Re: Superheater Boiler Flues
PostPosted: Fri Oct 03, 2003 12:16 pm
Try Senior Boiler tube. They have swedging capabilities as well.
http://www.suppliersonline.com/supplier ... div_id=558
I have found that Anderson had the better prices though.
PostPosted: Fri Oct 03, 2003 12:45 pm
Try Karay Metals in Woodstock, NY. They list up to 5" for A179 & A192. They may be able to source 5-1/2" tubes(?)
If you haven't yet, go to www.thomasregister.com and type "boiler tubes" into the search box.
Karay Metals
PostPosted: Fri Oct 03, 2003 1:29 pm
> We have gone to Anderson the last couple of times we have needed tubes. They in turn have sourced the tubes from a German company. TVRM has then swaged the tubes. I know we have also combined orders with other steam locomotive owners to get better pricing.
Tim Andrews
TVRM
tandrews@tvrail.com
PostPosted: Fri Oct 03, 2003 2:16 pm
Call Potts Welding here in Delaware. They are a major supplier of boiler tubes and seem to have everything. I have been in the boiler business for over 20 years and they have never let me down.
Tom
Potts Welding and Boiler Repair
PostPosted: Fri Oct 03, 2003 8:41 pm
While there are several suppliers I have been told there are actually only twp real sources. The first is american made tubes through any one of many suppliers. These are rolled and welded and of a modern composition. The second is the German tubes through Anderson. The material composition used is closer to the "original stuff" than anything made in america, they are SEAMLESS and much cheaper than domestic tubes even after you factor in the shipping.
jasonsobczynski@yahoo.com
 Post subject: Re: Superheater Boiler Flues ...suggestion
PostPosted: Sat Oct 04, 2003 7:32 am
Stick with seamless tubing if you can afford it. It is much less like to fail and if it does fail it gives you a short defect at the angle of the piercing mill instead of a long rip down the weld.
The German mills (Krupp and Thyssen) were always our biggest competitors, way underselling USSLorain product.
lamontdc@adelphia.net
