It is currently Mon Oct 19, 2026 5:40 pm
 Post subject: Caboose Marker Lantern
PostPosted: Tue May 17, 2022 3:39 pm
What is the purpose of this slot?
 Post subject: Re: Caboose Marker Lantern
PostPosted: Tue May 17, 2022 3:51 pm
The shaft of the wick raiser slides over into it so you can close the door. Some lamp styles have a sliding retainer inside that holds the shaft in place so it doesn't slip back out and block the door as you're closing it.
G.
PostPosted: Tue May 17, 2022 4:01 pm
And my Hiram Piper (Canadian) version has the latch to keep the wick raiser out of trouble..........mld
PostPosted: Tue May 17, 2022 7:23 pm
Thank you. These didn't come with the burner, but I knew there was a good reason for it. They fit the brackets on my caboose! We're going to refurbish the caboose this year.
