It is currently Mon Oct 19, 2026 9:58 pm
 Post subject: Graham-White Air Gauge Tester - CO2 Cartridge Question
PostPosted: Thu Mar 31, 2022 11:42 am
Greetings! Does anyone have experience with Graham-White's model 706-000 air gauge tester? I'm specifically wondering if it requires Graham-White branded CO2 cartridges, or if another off-the-shelf cartridge would work as well. We found a supplier with a three week lead time on the cartridges, but I'm looking for some something I can purchase within the next week or two. (I didn't have much luck reaching GW's customer service department this morning, so I figured I'd throw this question out there...)
Tester:
https://www.grahamwhite.com/products/ai ... er-holster
CO2 Cartridge:
https://cloud1.shopsite.com/surf-pre/gr ... tails.html
Any insight is appreciated. Thanks in advance!
Joe Nugent
Trustee
Motive Power Superintendent
Rochester and Genesee Valley Railroad Museum
http://www.rgvrrm.org
 Post subject: Re: Graham-White Air Gauge Tester - CO2 Cartridge Question
PostPosted: Thu Mar 31, 2022 12:33 pm
Looks like a standard CO2 cartridge to me?
PostPosted: Thu Mar 31, 2022 1:27 pm
My experience is from 35 years ago, but back then, the salesman touted the advantage that their Carbon Dioxide cartridges didn't use a standard thread size, and so could not be used in employees' paint ball guns.
PostPosted: Thu Mar 31, 2022 1:39 pm
I think they are pretty cheap. Could just buy some and see if they fit. If they can't even attach then you could take them back.
PostPosted: Thu Mar 31, 2022 2:22 pm
I have not had to order them, but I have been told the Graham-White's will only work with the Graham-White tester.
PostPosted: Fri Apr 01, 2022 10:10 am
I've used that model tester many times. As long as the CO2 cartridge is of the right pressure, it should work just fine.
