It is currently Wed Oct 21, 2026 8:32 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: British Steam Railways About To Run Out of Coal
PostPosted: Thu Jan 07, 2021 9:59 am
PMC wrote:
Not sure if this "solution" would work with steam though: https://www.independent.co.uk/news/busi ... 80743.html
ok...? Market forces are generally dominant, if it was a higher ROI for utility COs globally to use coal, they would. The ROI now favors natural gas and other alternatives. These firms have a limited amount of capital resources and investing them in non coal alternatives makes more sense.
Sure govt regulations have pushed it in that direction, but the nail in the coffin is the comparative ROI on Coal vs alternatives.
PostPosted: Tue Jan 19, 2021 12:52 pm
Well, someone has approved a new mine......
https://www.bbc.co.uk/news/uk-politics-55721919
PostPosted: Tue Jan 19, 2021 1:40 pm
Is "Coking" coal going to be suitable in BTU and price for the heritage lines to use in their steam engines?
Brian
PostPosted: Tue Jan 19, 2021 2:01 pm
Brian
I don't think it will, but its more the fact that a new mine has been approved by the Local Authority and the Government have decided not to interfere in the decision made.
The BBC seem to have picked this up late, as it was mentioned elsewhere a week or so ago when I did some searching around. No response from the likes of the Heritage Railway Association or other bodies as yet...
PostPosted: Tue Jan 19, 2021 4:07 pm
Coking coal can be used if you take advantage of the volatile gasses which boil out of the coal on its way towards converting it to coke, while at the same time using the good high carbon stuff left as coke on the grates..... or of course given enough air it might act just like coal, since coal is coked by heating in the absence of air. I'd consider overfire jets and a good draft, or GPCS. I think the original steam locomotives in the 1820s started burning coke of memory serves. The question would be how costly it might be - or if there's a lower grade than metallurgical the mine produces that would do for us they need to get rid of.
PostPosted: Mon May 03, 2021 1:26 am
Aaaaannnnnnd it starts.
https://www.bbc.com/news/science-environment-56949426
Curbs on the sale of house coal and wet wood for household burning in England have come into force under new rules aimed at cutting air pollution.
People will still be able to use stoves and open fires but they will need to burn cleaner alternatives.
These are the first restrictions on what people can burn in their homes since the clean air acts of the 1950s.
More at the link.
PostPosted: Mon May 03, 2021 1:00 pm
More at the link.
I am truly surprised that wet wood is sold with the expectation that it will be burned before it is given time to dry out.
Brian
PostPosted: Mon May 03, 2021 8:35 pm
Greetings:
I'm sorry to contribute to "thread drift", however, Valley Railroad (dba: Essex Steam Train & Riverboat) has burned low sulfur, low volatile, coking coal for decades, purchased from Castle Rock Coal & Carbon (Chuck Welsh: 636-575-1243). For about the last 15 years or so it has come from a strip mine in the Williamsport, PA area (please note that I own stock in neither Castlerock or the coal mine).
Expensive? Yes, but that is part of the cost of doing business while keeping the State of Connecticut (sulfur content 2% or less) happy and our neighbors who don't want to see any smoke (the amount of smoke produced is partially dependent on the volatile content of the coal, what we buy was less than 35% when I last bought coal) happy as well.
Remember that the firing practice in the US is quite different than the UK: here the firebox door is always closed except when adding coal (don't mention the "smoke latch" on Butterfly fire doors) while from what I have seen in the UK, the firebox door is almost always left open while running.
Be well,
J.David
PostPosted: Tue May 04, 2021 9:50 am
Be well,
J.David
I agree. I was taught that sucking cold air over the fire was bad for the flues. I don't know if that is true, but that is what I was taught, and from the in-cab UK steam video I've seen, they do seem to leave the firebox door open a lot. They also fire with some really large lumps of coal as well, far larger than, say Cedar Point would ever allow.
PostPosted: Tue May 04, 2021 11:59 am
Funny you should mention that. Just last night I was watching a cab ride video of UK steam and I cringed at the way the fire door was left open even when working hard. I was wondering if it was a green crew or that was typical UK practice.
PostPosted: Tue May 04, 2021 1:57 pm
Generally speaking, the practice of locomotives here in Europe is to include what is called a smoke burner in the firebox (danish translation, might be different in England). Typically, it is a pressed sheet of steel that is formed into a curve, and looks like an elongated headlight visor. The purpose of the smoke burner, is to direct cold air under the brick arch when the door is open, allowing it to mix with the hot air from the fire. It also serves a second purpose in directing secondary air to where it can mix with the gasses and allow their complete combustion.
To my knowledge, locomotives that are run with the firebox door open, partially or fully, are equipped with this little feature. It is bad practice to do this on a locomotive that does not have it. I recall seeing a whole pile of them, and the forms to press them, during a shop tour of Tysley in Birmingham. My guess would be that the majority of GWR types have these installed or attached to the firebox door.
I have never seen a feature like this on an American locomotive before, but would love to hear about it should it exist.
Thread drift aside however, we in Denmark are following the plight of the UK heritage scene quite closely. We have been using coal from Wales and Poland, and are looking to try some from Germany shortly. I would like to go back to Welsh coal, but the issues of a stable market in the future will likely prevent that decision from being made again.
Stuart Harrod
Steam shop machinist
Nordsjællands Veterantog
Veterantoget.dk
PostPosted: Tue May 04, 2021 2:47 pm
Google Gas Producer Firebox and Overfire Jets.
PostPosted: Tue May 04, 2021 9:15 pm
Adding to the drift, this is a very instructional video about British practices and equipment: https://youtu.be/6QwfBCDZqxY .........mld
PostPosted: Wed May 05, 2021 6:11 am
At about 10:15, there is discussion about what I wrote. The film calls it a baffle plate, so that must be the UK terminology for it!
Stuart Harrod
Veterantoget.dk
