It is currently Wed Oct 21, 2026 12:32 pm
 Post subject: Dynamo and mobile radios
PostPosted: Sun Apr 04, 2021 11:27 am
I am working with an organization that is rebuilding a steam locomotive for operation. As we were calculating the electrical load of the locomotive electrical system, we discovered that the two way radio, (50 watt RF output) while transmitting, will put the 500 watt dynamo in an overload condition by about 30%. We have looked around our property for a larger capacity dynamo and only found other 500 watt dynamos.
Our operating department has requirements for trains that leave the yard to have a radio that is capable of clearly communicating with the base radio in our office from the end of the line. During our operations, we have already found out that a hand held radio is spotty at best for this.
My big question, what are the consequences of running the current dynamo in this condition? I know of one operation that does this, and they have gone through a couple of dynamos over several years due to bearing failure.
We do have other options that are being discussed. Such as adding a 12 volt battery or adding a second dynamo.
Ed
 Post subject: Re: Dynamo and mobile radios
PostPosted: Sun Apr 04, 2021 11:40 am
Some of the NKP Berkshires had up to FOUR generators, if I remember my reading correctly. Original lighting generator; Mars light; cab signal on the Chicago division; and radio. So there is a prototype.
PostPosted: Sun Apr 04, 2021 12:29 pm
Overloading the dynamo won't kill the bearings. Depending on the exact way the gen is built, it will hit a wall. The wall might be the 'horsepower' from the turbine, in which case it will slow down and loose voltage. The wall might be the cooling of the windings, in which case long term overloading will overheat it and cause failure. Worst case would be that it's electrically incapable of making the amperage you are asking from it, in which case it will just blow internally and die right away.
You could set it up to charge a small battery, peak draw would be supplied by the battery and the constant draw limited by the charger. You would also get the benefit of having a radio if you lost the dynamo for some reason.
Do they still make 32v railroad radios? That would seem to be a tiny market.
PostPosted: Sun Apr 04, 2021 12:43 pm
Don't have my notebooks handy, but recall that the MO6 dynamo was introduced to provide more current that the K2 series about when steam locomotives needed more electric power for accessories, radio included. Might call Bernie Watts at Backshop and see if he can provide more specifics. 303 424 6882
PostPosted: Sun Apr 04, 2021 1:46 pm
The clean cab locomotive radios have an internal power converter that has a wide range of input voltage that covers 74 volts which will convert it to 12 volts. The clean cab radios run on 12 volts (13.6 volts). There are 4 pins on the power plug of the radio. 2 are for the higher voltage and 2 are for 12 volts.
PostPosted: Sun Apr 04, 2021 3:43 pm
A related topic may be found here: http://www.rypn.org/forums/viewtopic.php?f=1&t=44907 .
PostPosted: Sun Apr 04, 2021 7:50 pm
What voltage do you plan on feeding it? It has a minimum of 58 volts DC input, or bypass the converter and it runs on 12v.
PostPosted: Sun Apr 04, 2021 8:33 pm
The bearings are the only parts that are actually very easy to find and replace. Do good grounding and stock up on a few replacements - you can get them off the shelf.
PostPosted: Sun Apr 04, 2021 10:37 pm
The radio that we will be using is regular commercial radio. We will be utilizing a DC/DC converter with an isolated ground to go from the +/-32 volts of the dynamo to 12 volts (13.6 volts) for the radio. We had one clean cab radio that was old enough that it was not narrow band capable. We did price out a new clean cab radio. We went with the commercial radio versus the $3500 clean cab radio when we replaced all of our radios with narrow band programming.
The commercial radio works for our operation and will work with our neighboring railroad if needed.
Ed
PostPosted: Mon Apr 05, 2021 1:49 pm
Rayonier Inc. put a second 12 volt dynamo on their steamers to power the radios.
PostPosted: Tue Apr 06, 2021 9:21 am
Last edited by Kelly Anderson on Fri Aug 30, 2024 2:06 pm, edited 1 time in total.
PostPosted: Tue Apr 06, 2021 7:28 pm
Thank you everyone for the information, especially Kelly Anderson. With this information, I am comfortable about running it as is. We have the original dynamo that was last on the engine and a spare that have recently gone to an electric motor shop that, surprising to us, has done work on steam dynamos in the past.
We are currently using Wilmore converters in our Diesel locomotives and are planning to use the appropriate one for the steam locomotive.
Ed
PostPosted: Wed Apr 07, 2021 12:15 am
Perhaps load can be decreased by replacing incandescent bulbs with LEDs in places where the change will not be noticed. Not the headlight God forbid but the class lights, illuminated numbers on the headlight sides (if equipped), cab lights, gauge lights etc. Use warm white devices.
PostPosted: Wed Apr 07, 2021 4:00 am
We bought E26 32v G45S and and E26 32V G50S bulbs for Alaska Railroad 557. These are warm white 3 and 5 watt LEDs. The receipt says they come from Independence Electric Company, but no web page or address is listed.
They look good on "shore power" in the shop but we don't have any experience yet with them on generator power or on the road.
PostPosted: Wed Apr 07, 2021 8:26 pm
Thanks for the info, Dick. Might these be the folks?: https://independenceled.com/ ..mld
PS - Would you mind sharing the cost of each type of lamp?
After looking a bit more these folks are calling themselves the "New site of Independence Electric" : https://wattalight.com/
