It is currently Sun Oct 25, 2026 2:20 am
 Post subject: What locomotive is this?
PostPosted: Wed Aug 13, 2003 1:05 pm
Anyone know what locomotive this is? It is at the Steam Show in Hesston, Indiana. Can't tell whether it is two or three-foot gauge.
http://timlinux.goshen.edu/pn/modules.php?set_albumName=hesston&id=bainter635&op=modload&name=gallery&file=index&include=view_photo.php
ryarger@rypn.org
 Post subject: Re: What locomotive is this?
PostPosted: Wed Aug 13, 2003 1:43 pm
It appears to be 2' gauge, and from the cylinders and dry pipes to have started life as a (probably German) well-tank locomotive. The saddle appears to be fabricated from sheet steel during 'restoration' to cover the dry and exhaust pipes, rather than a two-piece casting including the cylinders, bolted together at the center line, which was usual US practice. Looks like a European locomotive that was "americanized". Anybody else have other comments?
Chris H.
 Post subject: Re: a little more info
PostPosted: Wed Aug 13, 2003 4:01 pm
seems like the societies webpage is down but the link below gives a little more info
http://www.michigancity.com/Hesston/Hesston.html
lamontdc@adelphia.net
PostPosted: Wed Aug 13, 2003 7:59 pm
It's a two foot gauge engine from Sandly Locomotive Works that was built from an old German engine for the Brookfield Zoo.
timsb@goshen.edu
PostPosted: Wed Aug 13, 2003 9:57 pm
We had a discussion of these engine some time back. this engine started life as a WW1 German Feldbahnn trench job. If the runnin gear has been unaltered, it should have swinging (steerable)front and rear axles. not really a bad job of "Americanizing" a very German teakettle.
