It is currently Fri Oct 23, 2026 10:12 pm
 Post subject: Belpaire firebox in Yard.
PostPosted: Sun Aug 16, 2020 9:27 pm
Went shopping this week at a Salvage Yard. These were there. Off a loco or stationary?
 Post subject: Re: Belpaire firebox in Yard.
PostPosted: Sun Aug 16, 2020 9:28 pm
Side view past the wheel pile.
PostPosted: Sun Aug 16, 2020 10:25 pm
Someone must need that archbar truck in the second picture?
M. Nix
M. Nix
PostPosted: Sun Aug 16, 2020 11:41 pm
Please correct me if i’m wrong, but those seem to be stationary boilers. Note the two firebox doors instead of one “Butterfly” door in the center. I believe that most, if not all locomotive boilers had one large door for the firebox.
PostPosted: Mon Aug 17, 2020 8:59 am
Mechanically operated firedoors came into use around 1915-1920. Plenty of locomotives never had them. And double firedoors were commonly used on wide fireboxes (anthracite/culm burners).
These are certainly locomotive-style boilers, with a very probable PRR pedigree or connection.
PostPosted: Mon Aug 17, 2020 10:19 am
Oh, Howard. Now you've done it.
PostPosted: Mon Aug 17, 2020 11:42 am
Last edited by Kelly Anderson on Thu Sep 05, 2024 3:47 pm, edited 2 times in total.
PostPosted: Mon Aug 17, 2020 3:14 pm
Marine boilers? Just because they were found in a scrapyard with railroad wheels and trucks does not mean they are rail related. Heavy scrap is heavy scrap-
PostPosted: Mon Aug 17, 2020 3:24 pm
I was going to suggest the same thing - marine or stationary just by looking at the back of the fire box and the orientation of the two doors. May not even be coal fired. This from a diesel guy....
PostPosted: Mon Aug 17, 2020 3:52 pm
Here is a link to a short thread that may also discuss these boilers.
viewtopic.php?f=1&t=24884&hilit=belpaire
I recall another thread with photos, but cannot easily find it using the search tool. I think the determination was these were marine boilers or another industrial use.
Is this the Kovalchik yard?
Wesley
PostPosted: Mon Aug 17, 2020 4:56 pm
Wesp,
Yes at Kovalchick’s
PostPosted: Mon Aug 17, 2020 5:40 pm
If they're at Kovalchick's then the person to ask would be Joe K himself; I'll guarantee the man knows where every pound of metal in his yard came from.
Alan Maples
PostPosted: Tue Aug 18, 2020 11:45 am
I have looked over those two boilers at length and they certainly are stationary boilers. I have no idea where they came from though.
PostPosted: Tue Aug 18, 2020 5:40 pm
The area that the business is in used to be the heart of the paper industry in PA, as well as the chemical industry. There were a lot of plants that converted hemlock into acid for tanning. Over the years these business' have gone by the wayside, and the Kovalchik's have scrapped a lot of plants, including inter plant narrow gauge rail equipment, as well as aforementioned power plants
PostPosted: Wed Aug 19, 2020 6:38 pm
Belpaire firebox boilers were originally installed at the Metropolitan Water Works pumping station in Chestnut Hill, MA, part of Boston's water supply system. They were part of the original construction of 1888. They were later replaced with vertical boilers in the 1920's.
Three of the steam pumps are still there in a museum which can be visited by appointment. They are housed in a beautiful Richardsonian building and include a massive 3 cylinder compound vertical engine and a unique 3 cylinder compound engine with rocker arms to transfer the power from the cylinders to the pumps. http://www.waterworksmuseum.org
Unfortunately they are now static displays, but are still awesome in their Victorian setting.
G. Cook
