It is currently Fri Oct 23, 2026 11:11 pm
 Post subject: Looking for Source of a 4-6-4 Diagram
PostPosted: Tue Apr 21, 2020 10:29 pm
A respondent from Germany is looking for the source of a diagram he found on a Wikipedia page, without attribution. It shows a 4-6-4 with a large trailing truck, labeled "Unitary Machinery Support as Applied to a 4-6-4 Type Locomotive." It is obviously not a NYC Hudson (note, e.g., the crosshead, not of the "alligator" type) and the longer trailing truck does not fit other 4-6-4s I could locate. The respondent is of the opinion that this is a proposal, perhaps early in the "super-power" era, not a locomotive that was actually built. Can anyone enlighten him as to the source of the diagram?
www.railarchive.net
 Post subject: Re: Looking for Source of a 4-6-4 Diagram
PostPosted: Tue Apr 21, 2020 11:14 pm
The trailing truck looks like the frame-extension type such as were under the Erie 2-8-4's versus the conventional type under the 4-6-4's that were actually built. Is that a booster on the rear axle? Really big boiler, too. Drivers look low for a 4-6-4.
Are there any dimensions?
PostPosted: Wed Apr 22, 2020 12:02 am
As far as I know, no other information. At least my German respondent hasn't provided any.
www.railarchive.net
PostPosted: Wed Apr 22, 2020 12:55 pm
Hi All
Looking at the diagram of the posted diagram, it was suggested by the other two posts, that the locomotive has low drivers. Well, I am more than likely wrong on this.
The Locomotive looks like a Boston & Albany J2c they were Lima built, I know the crosshead is wrong, in the attached photo. But that is my guest.
IMG_0022.jpg JPEG Image 750 × 249 pixels - Copy (2).jpg [ 30.08 KiB | Viewed 9188 times ]
PostPosted: Wed Apr 22, 2020 1:09 pm
Could it be the Lima proposal for the B&A J-2 with the articulated frame trailing truck as used in the Lima B&A A-1 2-8-4's?
PostPosted: Wed Apr 22, 2020 1:16 pm
That's 96% a Lima articulated trailing truck. The NYC Hudsons all had the more usual GSC cast-frame swiveling trailer.
I'm thinking this may have some relation to the ICRR rebuild of an early-style Lima 2-8-4 (which had those articulated trailers) into a "freight Hudson". One was rebuilt, but apparently, it was proposed to rebuild 50 2-8-4s to Hudsons. The one that was converted had a conventional GSC swiveling trailing truck. Perhaps this diagram showed the planned rebuilds, re-using the Lima truck?
PostPosted: Wed Apr 22, 2020 1:55 pm
The "front view" cut-away make me think "Narrow Gauge" if that's any clue. The driver spacing looks to be narrow, but that's only "Looks."
But it might be a clue.
Steamcerely,
David Dewey
PostPosted: Wed Apr 22, 2020 2:42 pm
I’m betting on artistic license of no particular locomotive. Big barrel, small drivers, narrow gauge and what looks like a simplified guess at a trailing truck booster. But as stated many times previously, I’m a diesel guy, what do I know....
PostPosted: Wed Apr 22, 2020 5:07 pm
I wonder if we aren't looking at either this....Frisco 4-6-4 1066...
https://donsdepot.donrossgroup.net/dr0605/fr1066.jpg
or an early version of this...B&O No. 2 Lord Baltimore...
https://www.flickr.com/photos/124446949@N06/36797014375
PostPosted: Wed Apr 22, 2020 6:07 pm
Both of those have Walschaerts valve hear. The drawing shows short frame Baker.
PostPosted: Wed Apr 22, 2020 7:18 pm
Not Frisco. I wonder if it isn't a proposed engine that was never built.
PostPosted: Wed Apr 22, 2020 7:38 pm
There's an earlier thread on this. Supposedly it's a W. E. Woodward (Lima) proposal for a branch line 4-6-4. Possibly 1928.
See:
viewtopic.php?f=1&t=35261&p=198741
PostPosted: Wed Apr 22, 2020 11:26 pm
I found it!
It's in the May, 1928 issue of Railway and Locomotive Engineering pp 142-145. Article is "Locomotive Design to Reduce Maintenance" by W. E. Woodard, VP of Lima Locomotive Works. The engine drawings are the 4-6-4 and a 2-12-6 (!) which must be seen to be believed. Both seem to have articulated trailing trucks. The drawings are not detailed and do not have dimensions.
If a 2-12-6 is hard to believe, remember in that period Alco built 88 4-12-2's for UP and Baldwin built a watertube-firebox compound 4-10-2 with 350 psi BP.
Here's a link:
https://archive.org/stream/railwaylocom ... 2/mode/1up
BTW the next article describes Baldwin's move to Eddystone.
PostPosted: Thu Apr 23, 2020 12:33 am
Great work, Phil! I will copy your info in both posts to the man in Germany.
www.railarchive.net
PostPosted: Thu Apr 23, 2020 1:52 pm
This locomotive looks quite similar, (to me at least) to the Illinois Central experimental freight 4-6-4 they rebuilt in the late 30’s from an older Berkshire. Not exactly of course but it fits the mold with the smaller drivers.
