It is currently Sat Oct 24, 2026 6:50 am
 Post subject: Vapor heat strips - Amtrak heritage cars
PostPosted: Wed Mar 04, 2020 11:48 am
Hi all,
Another project that I have never had to deal with before.
On Amtrak heritage cars they use heat strips. I am working on one is shot. While I am in there replacing, I am going to replace all.
Searching around on the Internet does not return any usable info.
Details of the units are Vapor # 1796739-01 heat strips. Amtrak wired 3 in series powered by 480 VAC.
Anyone have any experience finding a replacement for these?
Thanks,
Dale Grice
 Post subject: Re: Vapor heat strips - Amtrak heritage cars
PostPosted: Wed Mar 04, 2020 3:24 pm
One potential entry point would be here:
http://www.nwrail.com/nwre_products/heaters.html
I suspect people at this company can also advise you about both fabrication/restoration of and component sources for the specific units you have.
PostPosted: Fri Mar 06, 2020 10:11 am
Check the actual heat strip. At one end you should find the voltage & wattage stamped into the heater strip. When you have that information you can purchase replacement from the manufacturer Thermon
[/http://www.thermon.com/us/brands/caloritech/transit-heaters/floor-heaters-fv-sd-ss#specificationsurl]
PostPosted: Fri Mar 06, 2020 4:27 pm
HyRailer may have fallen foul of someone at the IETF. The more modern (i.e. secure in some snippety browsers) version of his link to Thermon, unmangled by URL-tag interference, is
https://www.thermon.com/us/brands/caloritech/transit-heaters/floor-heaters-fv-sd-ss#specifications
The direct link to 'find a sales rep' by region (which appears to be the way you start a request for technical information or to discuss this 'legacy' application) is
https://resources.thermon.com/reps/ths?filter=7
PostPosted: Tue Mar 10, 2020 3:54 pm
Thanks for the Thermon link and suggestion about data on the units. It was indeed on them. I have engaged Thermon and chromalux (sp?).
I did not find any info on the Internet when searching for the following units installed.
1. Wellman SS1-020101 w750 v240
2. 117-071393-053 OTF-24WX S80 240V 500W 1KL
Dale
