It is currently Sat Oct 17, 2026 11:29 am
 Post subject: TVRM Gets Norfolk Southern Office Car
PostPosted: Fri Jan 10, 2020 11:55 pm
Snipped from Facebook tonight:
If you are traveling Interstates 64 or 24 between St. Louis and Chattanooga this weekend be careful in the potentially bad weather but be on the lookout for our recently acquired office car former Norfolk Southern 8/Southern Railway 5. Originally built as the “Point Richmond” by Pullman in May of 1926 it was converted to an office car at Southern Railway’s Hayne Shops in 1956. It was purchased by TVRM from a private owner and it will be returning to TVRM were it once served as the speaker’s platform during the dedication of our Tunnel Blvd bridge in 1977. The car was purchased, and is being moved, through the incredible generosity of several donors.
The car was last privately owned and had been stored at Gateway Rail Services near St. Louis.
https://www.facebook.com/tvrail/photos/ ... 01/?type=3
 Post subject: Re: TVRM Gets Norfolk Southern Office Car
PostPosted: Tue Jan 14, 2020 10:22 am
Just curious why it was trucked instead of moved by rail. I'm not a facebook guy so didn't click on the link for the photos.
PostPosted: Tue Jan 14, 2020 11:14 am
It was sold minus trucks.
Andrew Durden
Chief Mechanical Officer
Southeastern Railway Museum
PostPosted: Tue Jan 14, 2020 2:55 pm
The Facebook post does not mention that. In response to the same question the the reply from Tennessee Valley Railroad Museum was
The car was not ready to be moved by rail and it made more sense to bring it down to Chattanooga. Our rail shop (Soule shop) has the equipment, man power, and knowledge to restore it to rail worthiness.
So was the car sold without trucks? -- or to expedite and simplify the relocation it was decided to move by road and overhaul the trucks and assemble the car at the Museum?
PostPosted: Tue Jan 14, 2020 3:20 pm
Previous owner sold the trucks before the car. New trucks have been/are being procured elsewhere. Much of the brake system was also stripped when work to Amtrak certify the car was underway.
PostPosted: Tue Jan 14, 2020 6:31 pm
Thank you.
Now I get an idea of what was/is happening.
PostPosted: Thu Jan 16, 2020 12:39 pm
Previous owner sold the trucks?? They were relatively modern three-axle trucks. I'll bet TVRM will have a hard time finding a matching pair. Older sets are pretty common.
PostPosted: Thu Jan 16, 2020 5:43 pm
It is my understanding that TVRM has a pair of trucks ready for this car, and everything else to make it happy.
I trust that TVRM knows what they are doing.
PostPosted: Fri Jan 17, 2020 3:32 pm
You misread me. The issue isn't whether or not they know what they're doing, because most assuredly they do. The issue, or rather question, is whether or not they can find a set of modern 3-axle OSH trucks to replace those now missing. I'm sure there are lots of older 3-axle trucks to be found, and maybe those are what they'll use. I will be curious to see.
PostPosted: Tue Jan 21, 2020 6:14 pm
They have a lot of stored rolling stock, so they most likely have what they need on hand. I recall from my time there that they had a few spare three axel trucks and frames on hand-one of they was used to demonstrate the 125 ton wrecker during public events.
PostPosted: Tue Jan 21, 2020 9:38 pm
I have been following the National Heights Rail Car group on facebook for years, this is a sweat-equity project to restore a former B&O obs car. Around eight years ago toward the start of the project they replaced the axles on their trucks with roller bearings (photo in red primer from 2011). Then around two years ago they replaced the truck frames (truck in silver, 2017 photo), caption: "New cast pedestal truck frames with on-frame brake cylinders arrived at the yard today. These will allow most of the brake rigging to be removed from the bottom of the car to make space for other things." So three axle trucks for heavyweight cars are definitely available. https://www.facebook.com/nationalheightsrailcar/
48209537_2282194735146196_8310159743733727232_o.jpg [ 178.06 KiB | Viewed 45979 times ]
18595207_1538627212836289_4922818461774488455_o.jpg [ 206.49 KiB | Viewed 45979 times ]
PostPosted: Wed Jan 22, 2020 7:45 am
This photo came to me this past Friday. Not sure where it came from, but it was on Facebook. Photo credit unknown.
PostPosted: Wed Jan 22, 2020 9:14 am
Anyone know why NS retired it for?
I've been thinking that she was perhaps due for a truck overhaul or some other expensive work and was deemed surplus after they inherited their portion of Conrail's fleet, but that's just a shot in the dark.
PostPosted: Wed Jan 22, 2020 11:02 pm
I don't mean to beat a dead horse here, but the pictures show ancient, obsolete trucks, one is even a bolted bolster truck from the '20's probably. The trucks which were on the NS business car were modern (1960's modern anyway) outside swing hanger cast trucks, probably GSC 62-UDO-11 6 wheelers. They are scarce and pricey when found. My point (long lost now) was the owner probably trying to make up for lost $ sold those pricey trucks to a PV owner wanting to upgrade. I don't have a picture. I'm sure there are pleanty of the old types around as there were lots of old passenger cars which were scrapped. Frankly, those old cast trucks look sorta goofy on the car.
Ned
PostPosted: Thu Jan 23, 2020 9:36 am
I think it was monday morning when I was watching the TVRM webcam and saw this car going by the Grand Junction station between diesels 1829 and TAG 80. So it has went the length of TVRM's line for a test I guess.
