It is currently Sat Nov 28, 2026 3:30 pm
 Post subject: IRM Acquires CLRV
PostPosted: Thu Nov 14, 2019 2:39 pm
https://www.irm.org/in-the-news/1979-st ... xkRXejCbVA
Jeff
 Post subject: Re: IRM Acquires CLRV
PostPosted: Thu Nov 14, 2019 2:47 pm
Very nice. What is the difference between the Toronto car's current gauge and IRM's and what will have to be done to accomplish the conversion? Thank you.
Also, here is a real-life permutation that I do not see in your graphic.
PostPosted: Thu Nov 14, 2019 3:13 pm
Toronto's gauge is 4'10&7/8", a difference of 2.375", so at a bare minimum, each wheel would have to be moved in 1.1875".
Jeff
PostPosted: Thu Nov 14, 2019 7:06 pm
Overheard the rumor to double track the entire IRM plant to both gauges last Wednesday.
PostPosted: Thu Nov 14, 2019 7:45 pm
Good one!
Does anyone on here know the story behind why Toronto chose their unusual gauge?
Greetings from Alberta
-an Articulate Malcontent
PostPosted: Fri Nov 15, 2019 2:03 am
SD70dude wrote:
Good one!
I think it was something about preventing standard gauge railways from using TTC (and their predecessors) tracks.
PostPosted: Fri Nov 15, 2019 8:46 am
That's exactly it. This dates back to the 1800's remember.
PostPosted: Fri Nov 15, 2019 8:49 am
You're not serious I hope. That would be insane to do for one car. Just swap out the wheels. Easier and cheaper.
PostPosted: Fri Nov 15, 2019 10:05 am
Baltimore went with 5' 4.5" for the same reason. It was also wide enough for wagons to fit between the rails.
PostPosted: Fri Nov 15, 2019 11:52 am
Sure, IRM has lots of spare seven inch wide wheels left over from the five foot gauge Russian Decapod conversion.
Actually, 4'-10 7/8" would be miserable to build three rail track for, since the 2 3/8" difference in gauge is less than the width of most rail heads, so the inner rail would impinge on the flangeway for the outer rail.
Since as I understand it these were designed to be the next generation 'standard' streetcar, I am sure the trucks are laid out to provide adequate wheel clearance for a variety of gauges, so it's likely just a matter of pressing the wheels in on the axles, with no other changes required.
PostPosted: Fri Nov 15, 2019 12:19 pm
Toronto's' track gauge is explained in a Wikipedia article - scroll to "Toronto Gauge"....
https://en.wikipedia.org/wiki/Track_gauge_in_Canada
"That the gauge of the said railways shall be such that the ordinary vehicles now in use may travel on the said tracks".
It must be true - I read it on the internet....
Bob Miller
PostPosted: Fri Nov 15, 2019 12:43 pm
Maybe just put the flanges on the outside? Switches would be bumpy but otherwise might work.....
PostPosted: Fri Nov 15, 2019 1:12 pm
Maybe by coincidence, the Toronto, Ont. streetcar gage is very clos to a Metric 1-1/2 meters.
PostPosted: Fri Nov 15, 2019 2:21 pm
So? Standard gauge is even closer to 1-7/16 meters, but typically the Metric mind can't deal in fractions anyway.
PostPosted: Fri Nov 15, 2019 3:15 pm
Question here, half-joking and full earnest: Were there any import tariffs on a Canadian-built streetcar? It's obviously not "US goods returned" as might be the case with most PCC cars. Any other complications for bringing it across the border?
/s/ Larry
